BOM configurations using iLogic
Message 1 of 10
I thought this one would be easy but is causing me some trouble. I have several BOM configurations that I need to export out of inventor. Right now I import the xml. file to get the configuration I want then check it before exporting the file. Is there a way to import the xml. file using iLogic?
My plan is to have the different BOM configurations set up as external rules and using a global form I can click on whatever BOM configurations I need to use. This way I just open the BOM and it’s ready to view or export.
I tried to change some code I found on here but just not getting me anywhere (code below). I would appreciate any help you might be able to give.
Sub BOM_ColumnCustomizasion_Export ()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Dim oAsmDef As AssemblyComponentDefinition
    Set oAsmDef = oAsmDoc.ComponentDefinition
    Dim oBOM As BOM
    Set oBOM = oAsmDef.BOM
    Dim filename As String
    filename = "c:\temp\BOM_Columns.xml"
    Call oBOM.ExportBOMCustomization(filename)
    Beep
End Sub
Sub BOM_ColumnCustomizasion_Import ()
    Dim oBOM As BOM
    Dim filename As String    'assume the file exists
    Call oBOM.ImportBOMCustomization(filename)
    Beep
End Sub
thanks
JD
Replies (9)
Message 2 of 10
frederic.vandenplas
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
Dim oBOM As BOM = oAsmDef.BOM
Dim filename As String = "Fullfilename of the xml"
Call oBOM.importBOMCustomization(filename)
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 10
Thank you. That is exactly what I needed
Message 4 of 10
Is there a way to open the BOM on the structure tab when this rule has been run?
Message 5 of 10
frederic.vandenplas
The BOM is allways opened at the tab that was activated when closing the BOM editor.
Maybe in the reg editor there is some option to do this?
Message 6 of 10
It doesn’t have to open on that tab. I just want to be able to use the code below and want it to open the BOM to view with the same rule.
SyntaxEditor Code Snippet
Dim filename As String = "P:\Engineering\Inventor\BOM List\Profit Key BOM.xml"
Message 7 of 10
frederic.vandenplas
Then this is what you need
'Open BOM editor dialog box
Dim oCtrlDef As ControlDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBillOfMaterialsCmd")
oCtrlDef.Execute
If you want to print all commandnames, there is a snippet in de vba help that does this, very helpfull and i have this file all the time with me Smiley Wink
Sub PrintCommandNames()
    Dim oControlDefs As ControlDefinitions
    Set oControlDefs = ThisApplication.CommandManager.ControlDefinitions
    Dim oControlDef As ControlDefinition
    Open "C:\temp\CommandNames.txt" For Output As #1
    Print #1, Tab(10); "Command Name"; Tab(75); "Description"; vbNewLine
    For Each oControlDef In oControlDefs
        Print #1, oControlDef.InternalName; Tab(55); oControlDef.DescriptionText
    Next
    Close #1
End Sub
Message 8 of 10
Thank you so much for your help. I’m still having a little trouble. Below is the code I’m using in visual basic for a button command. It is not understanding “Thisapplication” command. Frederic you code worked great when run in a rule. I just can get it to work in the application I’m trying to make. I would appreciate if you could look this code over to see what I’m doing wrong. I know that it’s close.
Thank you
  Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        If _invApp.Documents.Count = 0 Then
            MsgBox("Need to open an Assembly document")
            Return
        If _invApp.ActiveDocument.DocumentType <> _
        DocumentTypeEnum.kAssemblyDocumentObject Then
            MsgBox("Need to have an Assembly document active")
            Return
        Dim asmDoc As AssemblyDocument
        asmDoc = _invApp.ActiveDocument
        Dim oAsmDoc As AssemblyDocument = _invApp.ActiveDocument
        oCtrlDef.Execute()
  End Sub
Message 9 of 10
frederic.vandenplas
Thisapplication works in vba & illogic, just replace it with your _invApp and it will work if you _invApp is properly declared
Message 10 of 10
Thank you. I know it was something simple that I was over looking. Thanks again for your help.
