Body Selection in Drawing View from API
Hello Autodesk!
I am trying to follow the link below to get the body selection in a drawing but I can't convert this to c# code to use in my add-in.
https://forums.autodesk.com/t5/inventor-customization/select-body-in-drawing-view-from-drawing-curve...
Have a trick to do this?
My main problem is with the ModelGeometry to an occurrence, how this link below.
https://adndevblog.typepad.com/manufacturing/2014/10/expand-browser-and-select-part-by-selecting-edg...
I am use Inventor 2019 API.
Thanks!
Hello Autodesk!
I worked a little harder and found a solution. Below code snippet:
DrawingDocument doc = (DrawingDocument)m_inventorApplication.ActiveDocument;
HighlightSet highlight = doc.CreateHighlightSet();
DrawingView view = (DrawingView)m_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select the view!");
ObjectCollection items = m_inventorApplication.TransientObjects.CreateObjectCollection();
DrawingCurveSegment body = (DrawingCurveSegment)m_inventorApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select the bodies!");
DrawingCurve parent = body.Parent;
try
   EdgeProxy oModelprox = (EdgeProxy)parent.ModelGeometry;
   ComponentOccurrence compDef = oModelprox.ContainingOccurrence;
   DrawingCurvesEnumerator oCurveEnum = view.DrawingCurves[compDef];
   foreach (DrawingCurve oCurve in oCurveEnum)
          foreach (DrawingCurveSegment oSegment in oCurve.Segments)
              items.Add(oSegment);
              highlight.AddItem(oSegment);
catch (Exception)
I hope it helps!
Regards!
