Best practice for repetitive "case" code
Tony__Watkins
Tony__Watkins
I have a "case"  function to suppress components based on a length.  Though it is fairly simple code, the amount of input is large.  How can this be improved?  (Disclaimer: I have years of Inventor but only a few months of ilogic and no coding)
Michael.Navara
You can try something similar to this
'Bottom cover patterns on sheet 4 of spreadsheet 9/13/2023 have covered travel to 208", will continue as needed
'Not sure if there an easier way to code
Dim components As New Dictionary(Of String, Boolean)
components.Add("CBA004933:1", False)
components.Add("CBA004933:2", False)
components.Add("CBA004933:3", False)
components.Add("CBA004933:4", False)
components.Add("CBA004933:5", False)
components.Add("CBA004933:6", False)
components.Add("CBA004932-44:1", False)
components.Add("CBA004932-44:2", False)
components.Add("CBA004932-44:3", False)
components.Add("CBA004932-44:4", False)
components.Add("CBA004932-44:5", False)
components.Add("CBA004932-36:1", False)
components.Add("CBA004932-36:2", False)
components.Add("CBA004932-36:3", False)
components.Add("CBA004932-36:4", False)
components.Add("CBA004932-22:1", False)
components.Add("CBA004932-22:2", False)
components.Add("CBA004932-22:3", False)
components.Add("CBA004932-22:4", False)
components.Add("CBA004932-22:5", False)
components.Add("CBA004932:1", False)
components.Add("CBA004932:2", False)
components.Add("CBA004932:3", False)
Select Case True
    Case TR >= 137 And TR <= 144  '-44.1 only
        components("CBA004932-44:1") = True
    Case TR >= 145 And TR <= 149
        components("CBA004933:1") = True
    Case TR >= 150 And TR <= 158
        components("CBA004932-36:1") = True
        components("CBA004932-22:1") = True
    Case TR >= 159 And TR <= 163
        components("CBA004932-22:2") = True
    Case TR >= 164 And TR <= 172
        components("CBA004932:1") = True
    Case TR >= 173 And TR <= 180
    Case TR >= 181 And TR <= 184
        components("CBA004932-36:2") = True
    Case TR >= 185 And TR <= 192
        components("CBA004932-44:2") = True
    Case TR >= 193 And TR <= 194
        components("CBA004932-22:3") = True
    Case TR >= 195 And TR <= 199
        components("CBA004933:2") = True
    Case TR >= 200 And TR <= 208
End Select
For Each item As KeyValuePair(Of String, Boolean) In components
    Component.IsActive(item.Key) = item.Value
Next
CCarreiras
I believe there's a better way to do this, if you explain better what you want to achieve.
Probably using the pattern with formula will solve all that code.
Can you explain the conditions or share the model?
Look at this:
Anyway, I would use something like that to avoid such a long code:
'First clean all components
Component.IsActive("CBA004933:1") = False
Component.IsActive("CBA004933:2") = False
Component.IsActive("CBA004933:3") = False
Etc…
'Then, select the element needed for the size
If TR >= 137 And TR <= 144  then
Component.IsActive("CBA004933:1") = True
Elseif  TR >= 145 And TR <= 149  then
Component.IsActive("CBA004933:2") = true
Elseif  TR >= 150 And TR <= 154  then
Component.IsActive("CBA004933:3") = true
Etc…
End if
CCarreiras
JelteDeJong
It can be done without "if" or "case" statements. This technique is not always the best but in this case, you might get away with it. It also gives you some good insights. For example, I noticed that some components never get turned on.
Component.IsActive("CBA004933:1") = (TR >= 145 And TR <= 149) Or (TR >= 181 And TR <= 184) Or (TR >= 185 And TR <= 192) Or (TR >= 195 And TR <= 199)
Component.IsActive("CBA004933:2") = (TR >= 195 And TR <= 199)
Component.IsActive("CBA004933:4") = False
Component.IsActive("CBA004933:5") = False
Component.IsActive("CBA004933:6") = False
Component.IsActive("CBA004932-44:1") = (TR >= 137 And TR <= 144) Or (TR >= 159 And TR <= 163) Or (TR >= 173 And TR <= 180)
Component.IsActive("CBA004932-44:2") = (TR >= 185 And TR <= 192)
Component.IsActive("CBA004932-44:3") = False
Component.IsActive("CBA004932-44:4") = False
Component.IsActive("CBA004932-44:5") = False
Component.IsActive("CBA004932-36:1") = (TR >= 150 And TR <= 158) Or (TR >= 173 And TR <= 180)
Component.IsActive("CBA004932-36:2") = (TR >= 181 And TR <= 184) Or (TR >= 200 And TR <= 208)
Component.IsActive("CBA004932-36:3") = False
Component.IsActive("CBA004932-36:4") = False
Component.IsActive("CBA004932-22:1") = (TR >= 150 And TR <= 158)
Component.IsActive("CBA004932-22:2") = (TR >= 159 And TR <= 163)
Component.IsActive("CBA004932-22:3") = (TR >= 193 And TR <= 194)
Component.IsActive("CBA004932-22:4") = False
Component.IsActive("CBA004932-22:5") = False
Component.IsActive("CBA004932:1") = (TR >= 164 And TR <= 172) Or (TR >= 193 And TR <= 194) Or (TR >= 200 And TR <= 208)
Component.IsActive("CBA004932:2") = False
Component.IsActive("CBA004932:3") = False
Jelte de Jong
Blog: hjalte.nl - github.com
Tony__Watkins
Michael,
Thanks for the help, I love seeing how others would accomplish the same task.  Like I said in my post, I am new to the ilogic/coding.  Can you explain line 4 and line 80-82 of your program, I am not familiar with these commands and what they are doing.
Thanks for your time!!
Michael.Navara
Line 4: Here is initialized new Dictionary. It is a collection of pairs KEY-VALUE. In this case the key is of type string and contains occurrence name. Value is of type Boolean and contains information if the occurrence should be active (by default I set it to false).
Line 80: I iterate all items in the Dictionary and use key and value of each item.
Line 81: When I call Component.IsActive I use item.Key as occurrence name and item.Value as IsActive new value.
Line 82: End of loop. Go to next item in Dictionary
This approach allows you to choose (set) component IsActive state separately before you make any changes. If any exception occurs during Select, you have unmodified model.
