Best approach to support several UI languages
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
this is another (not directly related to Inventor) beginner-coder question:
I wonder which is the best approach to provide software product with several UI localizations?
I used to support two languages (my native and English).
I'm doing it in I believe not very smart way. In iLogic it looks somewhat like:
Sub Main
Dim sMsgTitle, sMsgBody, sLC As String
sLC = ThisApplication.LanguageCode
If sLC = "it-IT"
sMsgTitle = "Il mio saluto"
sMsgBody = "Ciao mondo"
Else
sMsgTitle = "My Greeting"
sMsgBody = "Hello World"
MessageBox.Show(sMsgBody, sMsgTitle)
End sub
The worst thing about the way mentioned - I don't see easy way to split sentences with values of variables when necessary. I then use several separate strings (one for Sentence begin, ... , ..., and one for sentence ending.
I believe I need to use at least some variable value placeholders, right?
Or should I hard-code every sentence in English and connect some external resource file(s) from which those string values would be substituted (if applicable)?
How you, professionals , do all this stuff?
Please vote for Inventor-Idea Text Search within Option Names
Michael.Navara
This is very complex task, how to use localization in your code.
I recommend you to avoid to use localization in iLogic.
But in Add-Ins it is a different. You can use very robust tools from .NET System.Resources Namespace
How to use this is too complicated for this forum post. See some references on the internet. There are many useful links and samples.
Here is few screenshots from sample project
Resources can be found at Project settings page in VS
Usage looks like this
Maxim-CADman77
@Michael.Navara
Sorry for re-asking but what about using variable value in the middle of the string.
Let say I have string variable sAAA and it has value "10th"
How should I organize things so that my sMsgBody values be "Ciao, 10th mondo" and "Hello, 10th World!" accordingly?
Michael.Navara
This is easy. You can have placeholders in localized strings.
'it: "Ciao, 10th mondo" => "Ciao, {0} mondo"
'en: "Hello, 10th World!" => "Hello, {0} World!"
dim msgFormat = "Ciao, {0} mondo" ' Can be obtained from My.Resources
MsgBox(String.Format(msgFormat, "10th"))
