Bendnote Ilogic
Bendnote Ilogic
Darkforce_the_ilogic_guy
Advisor Advisor
Message 1 of 8
Bendnote Ilogic
Is there a way to get ilogic to check it there is any Bendnote on the Drawing ?
Replies (7)
Message 2 of 8
Sergio.D.Suárez
Hello, I use this code to add blessings to all views that are unfolded
First delete the existing bend, then add the new bend.
You can specify a font and height, it is an example that searches in all the sheets, you can select part of the code that you need
Sub Main
	Dim tip As Document = ThisDoc.Document
	If tip.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then
		Delete_BendNote
		Add_BendNote
	Else
		MessageBox.Show("You must open a drawing file", "Add BendNote_All Sheet")
End Sub
Sub Delete_BendNote()
Dim oDrawDoc As Document
oDrawDoc = ThisDoc.Document
For Each oSheet In oDrawDoc.Sheets
For Each oGeneralNote In oSheet.DrawingNotes.bendnotes
oGeneralNote.Delete
Next
Next
End Sub
Sub Add_BendNote()
sFont = "ISOCPEUR" ' "ISOCP_IV25" 'Font Note
sFSize1 = 0.25 'Font Size in cm
Dim oSheet As Sheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
oDoc = ThisApplication.ActiveDocument
oSheet = oDoc.ActiveSheet
For Each oView In oSheet.DrawingViews
For Each oCurve In oView.DrawingCurves
If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge Then
oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
d1= "<StyleOverride Font='" & sFont & "' FontSize='" & sFSize1 & "'>" & oBendNote.Text & "</StyleOverride>"
oBendNote.FormattedText= d1
oBendNote.HideValue=True
Next
Next
Next
End Sub
 I hope it helps solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 3 of 8
Thanks for to code .. I might use to  make some upgrade to the code I already have...but My problem is that I must of the time I just want to add all the bent note, but not always… so I want it to add all if there is no bent note at all.  But it there are some it shall do nothing.
This is because I know that we have a few drawing where add all bent note will be too mush … I what I want to do is to save time by make ilogic add bent note on by before save … but if I need to delete some of them … I do not work this code to override my work
Message 4 of 8
Hi, Here you have a simplified code. If there is a bendnote in a sheet, it will not do anything on that sheet. If there is no bendnote in a sheet, add bendnotes to that sheet. To do this, count the number of bendnotes per sheet, and if they are equal to zero, activate the code.
I'm not sure this is what you want, I hope it helps you develop your code. regards
oCount = oSheet.DrawingNotes.bendnotes.count
	If oCount = 0 Then
			Next
		Next
Next
Mechanical Designer
Message 5 of 8
I did do some minor changes but all in all .. that was just what I needed thanks
Message 6 of 8
Crstiano
Hi Sergio,
Do you have some tip for edit the position of the BendNotes ?
I tried:
Sub AlignBendNotes()
Dim oDoc As DrawingDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDoc.ActiveSheet
Dim oDrawingNote As DrawingNote
Dim oDrawingNotes As DrawingNotes
Dim oNotes As ObjectCollection
Set oBendNotes = oSheet.DrawingNotes.BendNotes
For n = 1 To oBendNotes.Count
    Dim oPos As Point2d
    Set oPos = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.DrawingViews.Item(3).Center.X + (oSheet.DrawingViews.Item(3).Width / 2) + 3 _
    , oBendNotes.Item(n).Position.Y)
    oBendNotes.Item(n).Position = oPos
Next
 oDoc.Update
End Sub
And for any reasons nothing happens..
Are there suggestions or include in your example code, how to set the position when add the bendnote.
Thanks in advance.
Cristiano Oliveira
ConsultCAD.com
Message 7 of 8
Crstiano
The solution.
 oBendNote.Position = ThisApplication.TransientGeometry.CreatePoint2d(X, Y)
Cristiano Oliveira
ConsultCAD.com
Message 8 of 8
Sergio.D.Suárez
Excuse me, I just see the notification. I'm glad you solved the problem!
Mechanical Designer
