Bendline information from selected bend extend line in drawing
LarsBJepsen
LarsBJepsen
As a sub of a code i'm writing, I need to access the bendline information refered by a selected bend extendline. In other words: i select a bend extend line, and would like to get information about the bend. Any suggestions?
JhoelForshav
Hi @LarsBJepsen
I found some code here:
https://adndevblog.typepad.com/manufacturing/2013/08/inventor-access-sheet-metal-part-bend-informati...
, and rewrote it a bit for ilogic.
Try this ilogic rule to get bend information from bend line 🙂
Sub Main
	Dim oDoc As DrawingDocument
	oDoc = ThisApplication.ActiveDocument
	'Gets the selected curve segment
	Dim oDwCurveSegment As DrawingCurveSegment
	oDwCurveSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select bend line")
	Try
		'Gets full drawing curve from the segment
		Dim oDrawingCurve As DrawingCurve
		oDrawingCurve = oDwCurveSegment.Parent
		'Gets edge
		Dim oEdge As Edge
		oEdge = oDrawingCurve.ModelGeometry
		'Retrieves component definition from the edge
		Dim oSMDef As SheetMetalComponentDefinition
		oSMDef = oEdge.Parent.ComponentDefinition
		Dim oFlatPattern As FlatPattern
		oFlatPattern = oSMDef.FlatPattern
		'Gets flat bend result corresponding to the edge
		Dim oBendResult As FlatBendResult
		oBendResult = oFlatPattern.FlatBendResults.Item(oEdge)
		Dim oReturnString As String = String.Empty
		'Prints Flat Bend Results
		oReturnString = oReturnString & "---------------- Flat Bend Infos ----------------" & vbCrLf
		oReturnString = oReturnString & "Internal Name: " & oBendResult.InternalName & vbCrLf
		If oBendResult.IsOnBottomFace Then
			oReturnString = oReturnString & "Bend On Bottom Face" & vbCrLf
		Else
			oReturnString = oReturnString & "Bend On Top Face" & vbCrLf
		Dim oUOM As UnitsOfMeasure
		oUOM = oDoc.UnitsOfMeasure
		oReturnString = oReturnString & "Bend Angle  = " & oUOM.GetStringFromValue(oBendResult.Angle, kDefaultDisplayAngleUnits) & vbCrLf
		oReturnString = oReturnString & "Bend Radius = " & oUOM.GetStringFromValue(oBendResult.InnerRadius, kDefaultDisplayLengthUnits) & vbCrLf
		If oBendResult.IsDirectionUp Then
			oReturnString = oReturnString & "Bend Direction: " & "Bend Up" & vbCrLf
		Else
			oReturnString = oReturnString & "Bend Direction: " & "Bend Down" & vbCrLf
		Beep
		MsgBox(oReturnString)
	Catch
		GoAgain = MessageBox.Show("This is not a bend line, select another line?", "Show bend info", MessageBoxButtons.YesNo)
		If GoAgain = 6 Then
			Main()
		Else
			Exit Sub
	End Try
End Sub
LarsBJepsen
Thanks, but in this case i need to select the bend line in order to retrieve the information. I would like to select a bend extend line and then get the information from the corresponding bendline.
