bending angle create automatic note to export in a dxf
I would to create an automatic note using the angle of the sheet metal part that can be export in my dxf.
Example: -90° that will appear in my dxf.
My software machine recognize the angle of the 3d that need to appear in my dxf.
bhavik4244
@Anonymous
This may solve your issue.
Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDoc.ActiveSheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
Dim oViews = oSheet.DrawingViews
For Each oView In oViews
		For Each oCurve In oView.DrawingCurves
			If (oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
				Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge) Then
	oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
				If oBendNote.Text.Contains("DOWN") Then
					Dim oText = Replace(oBendNote.Text, "DOWN", "DOWN")
					oBendNote.HideValue = True
					oBendNote.Text = oText
				If oBendNote.Text.Contains("UP") Then
					Dim oText = Replace(oBendNote.Text, "UP", "UP")
		Next
	Next
Bhavik Suthar
Hi @bhavik4244 ,
We try your code but it gives us the following errors..
We need to change the code.
Do you have a solution ?
Thanks in advance.
Tommy.
bhavik4244
@Anonymous
remove the SubTest() and try to run...
Bhavik Suthar
Moverano
first, my congratulations for great ideas thaht arrive to forum. I'm a problem with code, I use on version 2015. Any ideas?  @Anonymous @bhavik4244
Error on line 12: End of statement expected.
