Batch print in numerical order
peterjoachim
peterjoachim
So I have this rule for batch printing, it checks the sheet sizes and sends different size sheets to different printers. It works great except for one thing.. It doesn't print in numerical order. Is there a way in iLogic to sort the components of an assembly and then print them in that order?
'THIS RULE WILL PRINT THE .idw OF ALL COMPONENTS IN THE ACTIVE ASSEMBLY
Dim Bldg1_Asize = "\\server3.eac.local\Design-CM"
Dim Bldg1_Bsize = "\\server3.eac.local\Design-CM"
Dim Bldg1_Dsize = "\\server3.eac.local\DESIGN-D2"
Dim Bldg2_Asize = "\\server3.eac.local\BUILDING2-CM"
Dim Bldg2_Bsize = "\\server3.eac.local\BUILDING2-CM"
Dim Bldg2_Dsize = "\\server3.eac.local\BUILDING2-D1"
'---PICK LOCATION OF PRINTERS---
PrintLocation = InputRadioBox("Where would you like to print?", "Bldg.1", "Bldg.2", booleanParam, Title := "Printer location")
Dim Aprinter As String
	If PrintLocation = True Then
	Aprinter = Bldg1_Asize
	Else
		Aprinter = Bldg2_Asize
Dim Bprinter As String
	Bprinter = Bldg1_Bsize
	Else
		Bprinter = Bldg2_Bsize
'Dim Cprinter =
Dim Dprinter As String
	Dprinter = Bldg1_Dsize
	Else
		Dprinter = Bldg2_Dsize
Dim Asize = 9987
Dim Bsize = 9988
Dim Csize = 9989
Dim Dsize = 9990
'---CHECK THAT THE ACTIVE DOCUMENT IS AN ASSEMBLY---
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'---DEACTIVATE VAULT---
Dim oVault As ApplicationAddIn
For Each oVault In ThisApplication.ApplicationAddIns
	If oVault.DisplayName = "Inventor Vault" Then Exit For
Next
If oVault IsNot Nothing Then oVault.Deactivate
'---DEFINE THE ACTIVE DOCUMENT AS AN ASSEMBLY---
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'---NOTICE REQUIRING USER INPUT---
RUsure = MessageBox.Show ( _
"You will be printing to Building 1." _
& vbLf & " This could take a while. Do you want to continue? " _
& vbLf & "", "Notice", MessageBoxButtons.YesNo)
Else
"You will be printing to Building 2." _
If RUsure = vbNo Then
	oVault.Activate
Return
Else
'---DETERMINE IF PRINTS SHOULD BE IN COLOR---
    oColorAsBlack="False"
    'RUsure = MessageBox.Show ( "Do you want to print this in COLOR?"& vbLf & "", "Color or B/W Prints",MessageBoxButtons.YesNo)
    'If RUsure = vbNo Then
    'oColorAsBlack="True"
    						'Return
    'Else
    'End If
    Dim oRefDocs As DocumentsEnumerator
    oRefDocs = oAsmDoc.AllReferencedDocuments
    Dim oRefDoc As Document
    numFiles = 0
'---COMPONENT DRAWINGS---
For Each oRefDoc In oRefDocs
        idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "idw"
        If (System.IO.File.Exists(idwPathName)) Then
            numFiles = numFiles + 1
            'If numFiles = 10 Then Exit Sub
        Dim oDrawDoc As DrawingDocument
            oDrawDoc = ThisApplication.Documents.Open(idwPathName, True)
            oDrawDoc.Activate
            oDrawDoc = ThisApplication.ActiveDocument
			oDrgPrintMgr = oDrawDoc.PrintManager
            oDrgPrintMgr.AllColorsAsBlack = oColorAsBlack
			If oDrawDoc.ActiveSheet.Size = Asize Then
				oDrawDoc.PrintManager.Printer = Aprinter
				oDrgPrintMgr.PaperSize = kPaperSizeLetter
				oDrgPrintMgr.Orientation = kLandscapeOrientation
				oDrgPrintMgr.ScaleMode = kPrintFullScale
			Else If oDrawDoc.ActiveSheet.Size = Bsize Then
				oDrawDoc.PrintManager.Printer = Bprinter
				oDrgPrintMgr.PaperSize = kPaperSize11x17
			'Else If oDrawDoc.ActiveSheet.Size = Csize Then
			'	oDrawDoc.PrintManager.Printer = Cprinter
			'	oDrgPrintMgr.PaperSize = kPaperSize17x22
			'	oDrgPrintMgr.Orientation = kLandscapeOrientation
			'	oDrgPrintMgr.ScaleMode = kPrintFullScale
			Else If oDrawDoc.ActiveSheet.Size = Dsize Then
				oDrawDoc.PrintManager.Printer = Dprinter
				oDrgPrintMgr.PaperSize = kPaperSize22x34
			Else
				MessageBox.Show("Sheet size not supported. Print will be scaled to fit on A size.", "Error")
				oDrgPrintMgr.ScaleMode = kPrintBestFitScale
			oDrgPrintMgr.PrintRange = kPrintAllSheets'Prints all sheets in the idw.
            oDrgPrintMgr.NumberOfCopies = 1 ' Set to print one copies.
            oDrgPrintMgr.SubmitPrint ' Submit the print.
            oDrawDoc.Close (True)
 Next
        'MsgBox ("There are " & numFiles & " sent to printer.")
'---TOP LEVEL DRAWING---
oAsmDrawing = ThisDoc.ChangeExtension(".idw")
If (System.IO.File.Exists(oAsmDrawing)) Then
oAsmDrawingDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
oAsmDrawingName = Left(oAsmDrawingDoc.DisplayName, Len(oAsmDrawingDoc.DisplayName) -3)
            oAsmDrawDoc = ThisApplication.Documents.Open(oAsmDrawing, True)
            oAsmDrawDoc.Activate
            oDrgPrintMgr = oAsmDrawDoc.PrintManager
			If oAsmDrawDoc.ActiveSheet.Size = Asize Then
				oAsmDrawDoc.PrintManager.Printer = Aprinter
			Else If oAsmDrawDoc.ActiveSheet.Size = Bsize Then
				oAsmDrawDoc.PrintManager.Printer = Bprinter
			Else If oAsmDrawDoc.ActiveSheet.Size = Dsize Then
				oAsmDrawDoc.PrintManager.Printer = Dprinter
			Else
            oAsmDrawDoc.Close (True)
  Else
      MessageBox.Show (" No IDW of the Top level file found!" _
    & vbLf & " " _
    & vbLf & "There were " & numFiles & " files sent to the printer."," Job Complete ")
  Return
'---REACTIVATE VAULT---
oVault.Activate
MessageBox.Show ("There were " & numFiles & " files sent to the printer."," Job Complete ")
'MessageBox.Show("New Files Created in: " & vbLf & idwpathname, "iLogic")'open the folder where the new ffiles are saved'Shell("explorer.exe " & oFolder,vbNormalFocus)
omartin
A couple of options, instead of looping and printing at the same time, You can create a list of the dwgs first, sort this list and then run the script from this sorted list. creates two loops but the first loop to generate the list I dont think will be noticeable. Other wise you will have to create a sorting algorithm on the fly maybe need some sort que object and check current dwg with the dwg next up to see which one should be printed leaving the other in the que.
Your folder structure; is it possible to have dwgs not related to the top assembly in there (dwgs yo dont want printed)? You can get the dwg list from the folder structure may be quicker than going through inventor.
Was my reply Helpful ? send a Kudos or accept as solution
peterjoachim
Unfortunately yes, there may be drawings I don't want to print, that aren't in the top level assembly, but are still in the folder.
I think your first suggestion sounds the simplest. (create list, sort list, run script from sorted list). I suppose you wouldn't have some sample code of this list creation? I did a quick search in the forums but didn't come up with much. I'm just getting into iLogic so my skills are limited but I'm learning quick thanks to the support here.
omartin
There are some handy snippets off to the side of the ilogic editor, you will find a variable section you can try out the arraylist
Dim MyArrayList As New ArrayList
MyArrayList.Add("c")
MyArrayList.Add("b")
MyArrayList.Add("a")
MyArrayList.Sort()
peterjoachim
Thanks for pointing me in the right direction. I have it working now and added a few more enhancements as well.
'This will print all the associated idws of an assembly.
Dim Asize = 9987
Dim Bsize = 9988
Dim Csize = 9989
Dim Dsize = 9990
Exit Sub
	Else
	Else
'Dim Cprinter =
	Else
	& vbLf & " This could take a while. Continue? " _
Else
Return
Else
'---DEFINE THE ACTIVE DOCUMENT---
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
Dim oJobNum As String = Left(oAsmName, 6)
Dim AsmPrefix As String = oJobNum & "-A"
'---CREATE LIST OF IDWs & MISSING IDWs---
Dim idwList As New ArrayList
Dim MissingList As New ArrayList
numFiles = 0
        idwPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) -3) & "idw"
		idwName = oRefDoc.DisplayName
		pJobNum = Left(idwName, 6)
		Prefix = Left(idwName, 8)
			If Prefix <> AsmPrefix Then
				idwList.Add(idwPathName)
			Else
				If pJobNum = oJobNum
				MissingList.Add(idwName)
Next
idwList.Sort
MissingList.Sort
'---CONVERT MISSING IDW LIST TO STRING---
Dim oText As String
For i As Integer = 0 To MissingList.Count - 1
	If i = 0 Then
		oText = MissingList(i)
		Else
			oText = oText & vbLf & MissingList(i)
Next
'---SHOW MISSING IDW LIST---
If oText = "" Then
	Else
RUsure = MessageBox.Show( _
	"No .idw found for.." _
	& vbLf & "" _
	& vbLf & oText _
	& vbLf & "" _
	& vbLf & "Continue?", "Notice", MessageBoxButtons.YesNo)
Return
Else
Next
'---PRINT IDWs FROM LIST---
For Each xVal In idwList
            oDrawDoc = ThisApplication.Documents.Open(xVal, True)
            oDrawDoc.Activate
			Else
 Next
oVault.Activate
omartin
Sound Great glad it worked out!
