Batch PDF ignoring one file
Dianna_Harding
Dianna_Harding
Been using the batch PDF code for years without issues, until today. It doesn't recognize one drawing even though I can pull it up and manually create a PDF. Says No top level assembly drawing found.
Would there be something else making this not recognize the .idw?
Files attached
A.Acheson
Hi @Dianna_Harding
Can you put a message box and determine if the filepath is correct? Sometimes it won't return the filepath your expecting.
This is the line of code that brings up that specific message. You could put this directly into the assembly file/part file the drawing is attached too, run it and and see does it open the file.
Try
		oAsmDrawingDoc = ThisApplication.Documents.Open(ThisDoc.ChangeExtension(".idw"), False)
	Catch
		MessageBox.Show("No top level assembly drawing found.", "Missing Drawing", MessageBoxButtons.OK)
	End Try
Regards
Alan
Dianna_Harding
The parent assy was referencing the wrong model. I should've thought of that, but long days happen. Thank you!
