Batch Export PDF - How to add iProperties to file name?
fredform
Message 1 of 11
fredform
Hello!
I've been modifying a batch PDF export script I originally found here and gotten things to work quite well but I would like to add Title and Revision to the PDF filename that gets generated but I can't seem to access the iProperties of each occurrence.
'Source: https://forums.autodesk.com/t5/inventor-customization/ilogic-batch-export-pdf-from-assembly-drawing/td-p/7325967
Sub Main()
    Dim oDoc As Document
    oDoc = ThisDoc.Document
    oDocName = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\" & System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
    If Not (oDoc.DocumentType = kAssemblyDocumentObject Or oDoc.DocumentType = kDrawingDocumentObject) Then
        MessageBox.Show("Please run this rule from an assembly or drawing file.", "iLogic")
        Exit Sub
    'Get user input
    If MessageBox.Show ( _
        "This will create a PDF file for all of the files referenced by this document that have drawings files." _
        & vbLf & "This rule expects that the drawing file shares the same name and location as the component." _
        & vbLf & " " _
        & vbLf & "Are you sure you want to create PDF Drawings for all of the referenced documents?" _
        & vbLf & "This could take a while.", "iLogic  - Batch Export PDFs ",MessageBoxButtons.YesNo) = vbNo Then
        Exit Sub
    Dim PDFAddIn As TranslatorAddIn
    Dim oContext As TranslationContext
    Dim oOptions As NameValueMap
    Dim oDataMedium As DataMedium
    Call ConfigurePDFAddinSettings(PDFAddIn, oContext, oOptions, oDataMedium)
	'Export location
	oFolder = "C:\temp_InventorExports\"
	'oFolder = oDocName & " PDF Files"
    If Not System.IO.Directory.Exists(oFolder) Then
        System.IO.Directory.CreateDirectory(oFolder)
 	'Integers for counting documents
	Dim iTotal As Integer
		iTotal = 0
	Dim iMissing As Integer
		iMissing = 0
	'List for missing drawings
	Dim sNoDrawList As String
    '- - - - - - - - - - - - - Component Drawings - - - - - - - - - - - -
    Dim oRefDoc As Document
    Dim oDrawDoc As DrawingDocument
    For Each oRefDoc In oDoc.AllReferencedDocuments
		iTotal = iTotal+1
        oBaseName = System.IO.Path.GetFileNameWithoutExtension(oRefDoc.FullFileName)
        oPathAndName = System.IO.Path.GetDirectoryName(oRefDoc.FullFileName) & "\" & oBaseName
        If(System.IO.File.Exists(oPathAndName & ".idw")) Then
            oDrawDoc = ThisApplication.Documents.Open(oPathAndName & ".idw", True)
            oDataMedium.FileName = oFolder & "\" & oBaseName & ".pdf"
            Call PDFAddIn.SaveCopyAs(oDrawDoc, oContext, oOptions, oDataMedium)
            oDrawDoc.Close
			iCreated = iCreated + 1
        Else
			iMissing = iMissing + 1
			sNoDrawList = sNoDrawList & vbLf & iMissing & ". " & oBaseName
    Next
    '- - - - - - - - - - - - - Top Level Drawing - - - - - - - - - - - -
    oBaseName = System.IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
    oPathAndName = System.IO.Path.GetDirectoryName(oDoc.FullFileName) & "\" & oBaseName
    If oDoc.DocumentType = kAssemblyDocumentObject Then
		iTotal = iTotal+1
        oDrawDoc.Close
    ElseIf oDoc.DocumentType = kDrawingDocumentObject Then
        Call PDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
   'Output prompt
    MessageBox.Show("New files created in: " & vbLf & oFolder & vbCrLf & vbCrLf & vbCrLf _
	& "Files found without drawings: " & vbLf & iMissing & " / " & iTotal & vbCrLf _
	& sNoDrawList, "iLogic")
    Shell("explorer.exe " & oFolder, vbNormalFocus)
End Sub
Sub ConfigurePDFAddinSettings(ByRef PDFAddIn As TranslatorAddIn, ByRef oContext As TranslationContext, ByRef oOptions As NameValueMap, ByRef oDataMedium As DataMedium)
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    oOptions.Value("All_Color_AS_Black") = 1
    oOptions.Value("Remove_Line_Weights") = 0
    oOptions.Value("Vector_Resolution") = 400
    oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'    oOptions.Value("Custom_Begin_Sheet") = 1
'    oOptions.Value("Custom_End_Sheet") = 1
    oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
End Sub
In another script found here the following function is used to build the string of Part number and Title with some separators. This seems like a good method to use for the Batch exporter as well but so far I haven't been successful in connecting the two.
Private Function BuildName(doc As Document) As String
    Dim name As String
    Dim designTrackProps As PropertySet
    designTrackProps = doc.PropertySets.Item("Design Tracking Properties")
	Dim designTrackProps2 As PropertySet
	designTrackProps2 = doc.PropertySets.Item("Inventor Summary Information")
	If designTrackProps.Item("Part Number").Value Is Nothing
		BuildName = doc.DisplayName
	Else
    name = designTrackProps.Item("Part Number").Value & " - [" & _
           designTrackProps2.Item("Title").Value & "]"
    BuildName = name
End Function
Happy for any suggestions on how to fix this!
Fredrik
Replies (10)
Message 2 of 11
WCrihfield
Where you get your oRefDoc variable from the line
Just pass that oRefDoc variable to the function, then use its returned value within the line you're using to save the PDF.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 11
rhasell
Hi
I have added a couple of lines to your code.
I have separated them by a --------- added by Reg-------- so that you can find the changes.
Sub Main()
        Exit Sub
    'Get user input
        & vbLf & " " _
        Exit Sub
	'Export location
	'-------Added By Reg---
	oRevNum = iProperties.Value("Project", "Revision Number")
		iTotal = 0
		iMissing = 0
		iTotal = iTotal+1
'---------------Changed by Reg------------------
            oDataMedium.FileName = oFolder & "\" & oBaseName & "[" & oRevNum & "]" & ".pdf"
            oDrawDoc.Close
        Else
    Next
		iTotal = iTotal+1
        oDrawDoc.Close
   'Output prompt
End Sub
End Sub
Reg
2026.1
Message 4 of 11
rhasell
Hi
Apologies, I forgot to add the title, you will have to format the filename as you see fit.
Sub Main()
	Exit Sub
'Get user input
If MessageBox.Show( _
	& vbLf & " " _
	& vbLf & "This could take a while.", "iLogic  - Batch Export PDFs ", MessageBoxButtons.YesNo) = vbNo Then
	Exit Sub
'Export location
oTitle=iProperties.Value("Summary", "Title")
iTotal = 0
iMissing = 0
	iTotal = iTotal + 1
	If (System.IO.File.Exists(oPathAndName & ".idw")) Then
		oDataMedium.FileName = oFolder & "\" & oBaseName & " - " & oTitle & "[" & oRevNum & "]" & ".pdf"
		oDrawDoc.Close
	Else
Next
	iTotal = iTotal + 1
	oDrawDoc.Close
'Output prompt
End Sub
End Sub
Reg
2026.1
Message 5 of 11
fredform
Hi Reg,
This only adds the top level assembly, or the iproperties of the document where the script is run to the filename of every pdf generated. I would like to have for each pdf include that documents Title and Revision number in the filename.
I will try to use the function as WCrihfield suggested and get back to you with the results.
Message 6 of 11
fredform
I have updated the code as below but I still cannot pass the information back from the function. I haven't worked with functions before so I'm kinda guessing on the syntax...
		BuildName(oRefDoc)
		'MsgBox(BuildName.Value)
		'MsgBox(BuildName)
		iTotal = iTotal+1
            oDataMedium.FileName = oFolder & "\" & oBaseName & BuildName & ".pdf"
            oDrawDoc.Close
        Else
    Next
And here's the function:
Private Function BuildName(oRefDoc As Document) As String
    Dim name As String
    designTrackProps = oRefDoc.PropertySets.Item("Inventor Summary Information")
	designTrackProps2 = oRefDoc.PropertySets.Item("Design Tracking Properties")
    name = "_" & designTrackProps.Item("Title").Value & "_Rev" & _
           designTrackProps2.Item("Revision Number").Value
    BuildName = name
	Return BuildName
End Function
Attached is the full code.
Message 7 of 11
WCrihfield
Try this.
I think I fixed it for you.
You were trying to get the Rev level from the wrong iProperties set.
You needed to set the returned value from the function as the value of a pre-defined string variable.
Etc, but I'm no longer getting errors from it.
Sub Main()
	Dim oThisDoc As Document = ThisDoc.Document
	oDocName = System.IO.Path.GetDirectoryName(oThisDoc.FullFileName) & "\" & System.IO.Path.GetFileNameWithoutExtension(oThisDoc.FullFileName)
	If Not (oThisDoc.DocumentType = kAssemblyDocumentObject Or oThisDoc.DocumentType = kDrawingDocumentObject) Then
	    MsgBox("Please run this rule from an assembly or drawing file.",vbOKOnly, "iLogic")
	    Exit Sub
	'Get user input
	If MsgBox("This will create a PDF file for all of the files referenced by this document that have drawing files." & vbLf &  _
		"This rule expects that the drawing file shares the same name and location as the component." & vbLf & vbLf & _
		"Are you sure you want to create PDF Drawings for all of the referenced documents?" & vbLf & _
		"This could take a while.",vbYesNo + vbQuestion, "iLogic  - Batch Export PDFs") = vbNo Then
		Exit Sub
	'Export location
	Dim oFolder As String = "C:\temp_InventorExports\"
	'Dim oFolder As String = oDocName & " PDF Files"
	Dim iTotal As Integer = 0
	Dim iMissing As Integer = 0
	Dim oBuiltName As String
	For Each oRefDoc In oThisDoc.AllReferencedDocuments
		oBuiltName = BuildName(oRefDoc)
		MsgBox(oBuiltName)
		iTotal = iTotal+1
	        oDataMedium.FileName = oFolder & "\" & oBaseName & oBuiltName & ".pdf"
	        oDrawDoc.Close
	    Else
	Next
	oBaseName = System.IO.Path.GetFileNameWithoutExtension(oThisDoc.FullFileName)
	oPathAndName = System.IO.Path.GetDirectoryName(oThisDoc.FullFileName) & "\" & oBaseName
	If oThisDoc.DocumentType = kAssemblyDocumentObject Then
		iTotal = iTotal+1
		oDrawDoc.Close
	ElseIf oThisDoc.DocumentType = kDrawingDocumentObject Then
		PDFAddIn.SaveCopyAs(oThisDoc, oContext, oOptions, oDataMedium)
	'Output prompt
	MsgBox("New files created in: " & vbLf & oFolder & vbCrLf & vbCrLf & vbCrLf & _
	"Files found without drawings: " & vbLf & iMissing & " / " & iTotal & vbCrLf & _
	sNoDrawList,vbOKOnly, "iLogic")
End Sub
Function BuildName(oDoc As Document) As String
	Dim oSumProps As PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
	Dim oTitle As String = oSumProps.Item("Title").Value
	Dim oRev As String = oSumProps.Item("Revision Number").Value
	Dim oName As String = "_" & oTitle & "_Rev" & oRev
	Return oName
End Function
End Sub
Wesley Crihfield
Message 8 of 11
WCrihfield
@fredform
Just a tip.  That last post I did may have fixed some main problems, but one thing I noticed that you may need to address to avoid possible future errors, is to check if those iProperties actually have a value or not.  If either of their value are empty, that might cause problems.  So putting a check in there to catch when either of those values are empty (""), and what to do if it is, will most likely help avoid future problems.
Wesley Crihfield
Message 9 of 11
WCrihfield
@fredform
Also, it you're wanting to make this batch PDF publisher to reach down to every level of all sub-assemblies, you will have to develop a loop with a GoTo that checks if the count of its AllReferencedDocuments (this sort of thing is usually done with ComponentOccurrences, and checking oOcc.SubOccurrences.Count).  If the count is more than zero, then GoTo the beginning of the loop again.  If the count is zero, continue without going back through the loop again.  Of course this is a mid-level loop though, because it needs to still proceed to the next oRefDoc, if there are any.
You can find similar workflow examples here on the forum.
Wesley Crihfield
Message 10 of 11
fredform
Hi again,
Thank you so much for the help! It is now working beautifully!
One thing I don't really understand though is why the function uses "oDoc As Document" and not "oRefDoc"?
Also about the iProperties set, you are right, I only looked at the iLogic snippets and iProperties tab where revision is under Project and assumed that would be the same here, oh well...
I've added a catch to fix if the iProperty field is empty although I didn't really get an error before if it was.
I didn't manage to use the function to populate the string for the top level assembly so I used the ilogic snippets to build that string, not as elegant of a solution but it works.
Also for the traversing down into multiple levels of subassemblies and their documents it seems to be working. On the files I've used for testing there is 3 levels of assemblies and the part documents in the lowest level gets printed as well so I guess it works?
Here is the finished code:
Sub Main()
    If Not oDoc.DocumentType = kAssemblyDocumentObject Then
        MessageBox.Show("Please run this rule from an assembly file.", "iLogic")
        Exit Sub
    'Get user input
        "This will create a PDF file for all of the files referenced by this document that have drawing files." _
        & vbLf & " " _
        Exit Sub
	'Export location
		iTotal = 0
		iMissing = 0
	Dim oProps As String
		oProps = BuildName(oRefDoc)
		iTotal = iTotal+1
            oDataMedium.FileName = oFolder & "\" & oBaseName & oProps & ".pdf"
			oDrawDoc.Close
        Else
    Next
	Dim oTopProps As String
		If Not iProperties.Value("Summary", "Title") = "" Then
			oTopProps = "_" & iProperties.Value("Summary", "Title")
		If Not iProperties.Value("Project", "Revision Number") = "" Then
			oTopProps = oTopProps & "_Rev" & iProperties.Value("Project", "Revision Number")
    oDataMedium.FileName = oFolder & "\" & oBaseName & oTopProps & ".pdf"
	iTotal = iTotal+1
        oDrawDoc.Close
   'Output prompt
End Sub
Private Function BuildName(oDoc As Document) As String
	Dim oRev As String
	Dim oName As String
	If Not oSumProps.Item("Title").Value = "" Then
		oTitle = oSumProps.Item("Title").Value
		oName = "_" & oTitle
	If Not oSumProps.Item("Revision Number").Value = "" Then
		oRev = oSumProps.Item("Revision Number").Value
		oName = oName & "_Rev" & oRev
	Return oName
End Function
End Sub
Really appreciate the help, thank you!
Best,
Fredrik
Message 11 of 11
WCrihfield
Good to hear it's working for you now.
Yes, I considered just getting rid of the subs & functions, and just doing it all by straight code, but I didn't know if there might be more to your code, or if you may be trying to access them from other processes.
The variable name supplied within a call to a function should always be different than the equivalent variable name defined within function's definition.  This is just good coding practice.  It helps ensure that the object or value being passed to the function is being received from that call only, and not just from the general code at whatever position within the code that the function's definition appears.  Keeps it separate and clean.
Wesley Crihfield
