Message 1 of 1
Batch export flat pattern dxf from iAssembly Factory
Hi Everyone/Anyone,
I am currently using below modified iLogic Code from another forum. It only works for a simple assembly and not for an entire iAssembly Factory. Please share your ideas and help me complete my code.
Dim oDoc As AssemblyDocument oDoc = ThisApplication.ActiveDocument Dim oAsmDoc As AssemblyDocument oAsmDoc = ThisApplication.ActiveDocument oAsmName = ThisDoc.FileName(False) 'without extension 'Check that the active document is an assembly file If oDoc.DocumentType <> kAssemblyDocumentObject Then MessageBox.Show("Please run this rule from the assembly file.", "iLogic") Exit Sub End If 'Get user input RUsure = MessageBox.Show ( _ "This will create a DXF file for all of the assembly components that are sheet metal." _ & vbLf & "This rule expects that the part file is saved." _ & vbLf & " " _ & vbLf & "Are you sure you want to create DXF for all of the assembly components?" _ & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo) If RUsure <> vbYes Then Exit Sub Dim oPath As String = ThisDoc.Path 'Get the DXF target folder path Dim oFolder As String = oPath & "\" & " DXF Files" 'Check for the DXF folder and create it if it does not exist If Not System.IO.Directory.Exists(oFolder) Then System.IO.Directory.CreateDirectory(oFolder) End If '- - - - - - - - - - - - -Component - - - - - - - - - - - - 'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) Dim oBOM As BOM 'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) oBOM = oDoc.ComponentDefinition.BOM 'MessageBox.Show("Test", "My iLogic Dialog", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1) oBOM.StructuredViewEnabled = True Dim oBOMView As BOMView = oBOM.BOMViews.Item(oBOM.BOMViews.Count) For Each oRow As BOMRow In oBOMView.BOMRows Try Dim oCD As ComponentDefinition = oRow.ComponentDefinitions.Item(1) Dim iDoc As Document = oCD.Document 'SheetMetal parts only If iDoc.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For Dim iName As String = iDoc.FullFileName 'Check that model is saved If iName = vbNullString Then Continue For iDoc = ThisApplication.Documents.Open(iName) oCD = iDoc.ComponentDefinition Dim oItem As String = oRow.ItemNumber Try If Not oCD.HasFlatPattern Then oCD.Unfold() Else oCD.FlatPattern.Edit() End If Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=IV_OUTER_PROFILE&InvisibleLayers=IV_TANGENT&BendDownLayerLineType=37644&BendUpLayerLineType=37644" Dim ShortName As String = Left(iDoc.DisplayName, (InStrRev(iDoc.DisplayName, ".", -1, vbTextCompare) - 1)) & ".dxf" oCD.DataIO.WriteDataToFile(sOut, oFolder & "\" & ShortName) oCD.FlatPattern.ExitEdit() Catch ex As Exception MsgBox(ex.Message) End Try iDoc.Close(True) Catch End Try Next
