Barcode and pdf
Barcode and pdf
GosponZ
Message 1 of 11
Barcode and pdf
GosponZ
I'm using rule to save pdf file and it is going smooth. Now i wanted to add barcode using idaAutomationSHC39M fonts. In drawing looks good, if i print pdf from Inventor code looks good but some king lines are over shaded views, and if i'm using export pdf  or iLogic rule barcode print is very bad.
Anybody has or solved this problem? Thanks for advice if there is any
Here is saved file as pdf
and here is how supposed to look
Replies (10)
Message 2 of 11
xiaodong_liang
Autodesk Support
Autodesk Support
Hi.
May I understand the situations are?
- by Inventor API code (translator addin), it works well
- by Inventor product (save as to PDF), it works bad
- by iLogic (using translator addin), it works bad
and could you provide a demo drawing?
Message 3 of 11
GosponZ
Yes that is correct.
I do not know what is problem in between export pdf from inventor and print pdf.
i have to say again only if i'm using  idaAutomationSHC39M barcode fonts
Thank you for your help
Message 4 of 11
xiaodong_liang
Autodesk Support
Autodesk Support
Hi ,
I tried to open xxx-0000.dwg, Inventor asks for XXX-0000.ipt, whiile you seemed not to upload such file. I asked Inventor to use xxx-0005.ipt, it failed. finally, I cannot get a drawing with the barcode. Could you check anything missed?
Message 5 of 11
GosponZ
I'm sorry looks like i pick wrong file.
Message 6 of 11
xiaodong_liang
Autodesk Support
Autodesk Support
it seems I still missed something. the barcode is string when I opened XXX-000.dwg at my side. And when I wanted to export it to PDF, it reported an error that one font is not acceptable. Could you check anything I need to set?
Message 7 of 11
GosponZ
Do you have those fonts? I do not know what else.
Message 8 of 11
xiaodong_liang
Autodesk Support
Autodesk Support
I do not think I have such font. Is this a specific font, or a common one that I can download? This reminds me to check whether the problem of barcode happened with this font?
Message 9 of 11
Crstiano
I use this font: Barcode_Font.ttf
The other FONTs:  3of9_barcode, eanbwrp72tt, free3of9 not work correctly. Because of satisfy each characteristic (only numbers, etc.).
Cristiano Oliveira
ConsultCAD.com
Message 10 of 11
GosponZ
Thank you for your comment.
Indeed this is working good with pdf, but only one thing is bad that our scaner can't read this barcode. 😞
Message 11 of 11
adam.nagy
Autodesk Support
Autodesk Support
Seems to be a similar issue to this one, for which I logged a change request:
http://forums.autodesk.com/t5/Inventor-Customization/Inventor-Drawing-gt-Barcode-gt-Export-PDF/td-p/...
Adam Nagy
Autodesk Platform Services
