Balloons Position, Spacing and Overlap
Ammar_HassanEHLNB
Message 1 of 1
Ammar_HassanEHLNB
Hi Experts,
I am trying to automate the balloons positions with ilogic. With the reference code i have, it does a good job to align all the balloons in active sheet to perfectly horizontal with respect to leader positions. However, sometimes the leader head arrows of two balloons get very close to each other making the balloons overlap as shown in sample picture i shared. I want the balloons to not get overlapped, stay aligned vertically.
Can you give it a look and propose a solution, appreciated.
@JelteDeJong
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim oTg As TransientGeometry = ThisApplication.TransientGeometry
For Each balloon As Balloon In sheet.Balloons
    Dim moveBalloonX As Double = 10
    Dim posRootNode As Point2d = Balloon.Leader.AllNodes(2).Position
    Dim viewPos As Point2d = Balloon.ParentView.Position
    Dim viewWidth As Double = Balloon.ParentView.Width
    Dim viewHeight As Double = Balloon.ParentView.Height
    Dim viewScale As Double = Balloon.ParentView.Scale
    If (viewPos.X > posRootNode.X) Then
        'LEFT PLACEMENT
        moveBalloonX = viewPos.X - (viewWidth*0.75) - (moveBalloonX * viewScale)
    Else
        'RIGHT PLACEMENT
        moveBalloonX = viewPos.X + (viewWidth*0.75) + (moveBalloonX * viewScale)
    Dim posBalloon As Point2d = oTg.CreatePoint2d(moveBalloonX, posRootNode.Y)
    Balloon.Position = posBalloon
Next
Replies (0)
