Balloon creation, stop jumping around!
StainlessBOB
StainlessBOB
Is there a setting I'm failing to find to allow me to pull a balloon away from a part and allow me to drop it where i want to? When pulling a balloon away from the part currently in 2017 it jumps wildly around and has to be adjusted after dropped.
Ron_Jones1122
The balloon command will allow you to place at your leisure. Just click 'B' or Baloon. Select the part you wish to balloon. Left click where you want the balloon. Then right click continue to place.
Ron Jones
Engagement Manager
Blog
LinkedIn
Jef_E
Press shift key to stop this behaviour.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
StainlessBOB
Just an update on my problem. Holding shift down does not make a difference.  I have talked around with other users and they have no issue such as mine. So I am guessing that it must be unique to my computer, video perhaps.  I have been dealing with this for some time now and will live with the "jumping balloons" almost like snaps being on.
Jef_E
If you would like to resolve this issue maybe you can create a screencast video to show the problem? Because juming balloons is not working as visualization for the problem.
Inventor 2014 SP2
StainlessBOB
I have attached a short video.  Thanks for your support
Jef_E
Okay, this is indeed really odd. Have you tried any methods to fix it? driver updates?
Inventor 2014 SP2
