Background image
Background image
Background image
Hi there.
I'm trying to make a simple macro to change back to my standard desktop background image.
I have come this far with my limited macro knowledge:
Public Sub Revertbackground()
ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType
ThisApplication.ColorSchemes.Item.ImageFullFileName.......
End Sub
Can anyone help me with the functionality of ImageFullFileName?
Kjetil
ludesroc
' Change the background type.
' Set the backgroud picture (Ex: Cloud).
ThisApplication.ActiveColorScheme.ImageFullFileName = "C:\Program Files (x86)\Autodesk\Inventor 2008\Backgrounds\Cloud2.bmp"
End Sub
Ludesroc.
Ludesroc
Superb.
Kjetil
Here is a little trick how to set white Backgroung (for PrintSrceen for example) without changing ohter colour settings (like lines on the sketch):
Public Sub Background_Image()
ThisApplication.ActiveColorScheme.ImageFullFileName = "C:\Program Files (x86)\Autodesk\Inventor 2014\Backgrounds\white.png"
If ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType Then ThisApplication.ColorSchemes.BackgroundType = kGradientBackgroundType Else ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType End If Run_CMD ("AppAmbientShadowCmd") End Sub Function Run_CMD(ByVal cmd As String) As Boolean ' Get the CommandManager object. Dim oCommandMgr As CommandManager Set oCommandMgr = ThisApplication.CommandManager ' Get control definition for the line command. Dim oControlDef As ControlDefinition Set oControlDef = oCommandMgr.ControlDefinitions.Item(cmd) ' Execute the command. Call oControlDef.Execute End Function
My whie.png file is all white as you can imagine.
good luck
