Automating Import, Save, and Rename Process in Inventor and Vault
arthur_d_law2
arthur_d_law2
Hello forum,
I downloaded a parts catalog in .stp format.
I would like to save them as .ipt files in a folder under Vault and then rename them.
Would it be possible to automate all of this instead of doing it manually step by step ?
Manually, the steps are as follows:
Open Inventor > create a new part > import > select the part > save > choose the save path and fill in the various fields in the Data Sheet > Ok
And then under Vault:
Rename the part > add the name in the description of the Data Standard after the Part Number > Ok
I imagine that anything done manually with Inventor should be possible to achieve through programming, but I’ve never used iLogic/API before, and since there’s a part in Inventor and one in Vault, I’m not sure how to proceed.
Do you have any suggestions, please ?
Thanks in advance
C_Haines_ENG
You may be waiting for a long time for a response to this, as this would require your tester not only having Inventor 2024+ AND Vault Pro.
This Video goes over many different scenarios and shows code for each, maybe you can piece it together.
