Automatically show reference planes in drawing views in Sub Assemblies **
Tiffany_Hayden_
Tiffany_Hayden_
I found this code in a previous post concerning Automatically show reference plans in drawing views and it works for what it was wrote for. But I would like to go down to the next level where I have two sub assemblies and turn on the reference planes at that level. Can anyone tell me or give me a direction of what needs to change to do that?
Thank you in advance.
    Dim oDwgDoc As DrawingDocument
    Set oDwgDoc = ThisApplication.ActiveDocument
    Dim oSht As Sheet
    Set oSht = oDwgDoc.ActiveSheet
    Dim oDwgView As DrawingView
    Set oDwgView = ThisApplication.CommandManager.Pick(kDrawingViewFilter, "Select view to show the origin plane")
    Dim oWP As WorkPlane
    If oDwgView.ReferencedDocumentDescriptor.ReferencedDocumentType = kPartDocumentObject Then
        Dim oPartDoc As PartDocument
        Set oPartDoc = oDwgView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oPartCompDef As PartComponentDefinition
        Set oPartCompDef = oPartDoc.ComponentDefinition
        For Each oWP In oPartCompDef.WorkPlanes
            oWP.AutoResize = True
            On Error Resume Next
            Call oDwgView.SetIncludeStatus(oWP, True)
        Next
    Else
        Dim oAssyDoc As AssemblyDocument
        Set oAssyDoc = oDwgView.ReferencedDocumentDescriptor.ReferencedDocument
        Dim oAssyCompDef As AssemblyComponentDefinition
        Set oAssyCompDef = oAssyDoc.ComponentDefinition
        For Each oWP In oAssyCompDef.WorkPlanes
        Next
Tiffany Hayden
Tiffany_Hayden_
I found a solution.
    Set oAssyDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
    Dim oComponentOccs As ComponentOccurrences
    Set oComponentOccs = oAssyDoc.ComponentDefinition.Occurrences
    Dim oCompOcc As ComponentOccurrence
    Dim oSubOccs As ComponentOccurrences
    Dim oSubOcc As ComponentOccurrence
    For Each oCompOcc In oAssyDoc.ComponentDefinition.Occurrences
        'Looking for normal BOM structure for C models that are not reference.
        If oCompOcc.BOMStructure = kNormalBOMStructure Then
           Set oSubOccs = oCompOcc.Definition.Occurrences
           For Each oSubOcc In oSubOccs
                Dim oPlane As WorkPlane
                'Finding the YZ Plane in the sub assemblies C models
                Set oPlane = GetDocWPl(oSubOcc.Definition.Document, "YZ Plane")
                'Making a Plane Proxy for the sub assembly C model
                Dim oPlaneProx As WorkPlaneProxy
                Call oSubOcc.CreateGeometryProxy(oPlane, oPlaneProx)
                'Proxy Plane for the Final Assembly D Model
                Dim oPlane_oAssy As WorkPlane
                Call oCompOcc.CreateGeometryProxy(oPlaneProx, oPlane_oAssy)
                oView.SetIncludeStatus oPlane_oAssy, True
            Next
    Next
Tiffany Hayden
