Automatically inserting parts
EmreYucel34
EmreYucel34
Hello, we will select the motor according to the part loads in the inverter nastran or in the inverter itself, can we make the motor selection in the animation about this, why am I asking this because there is such a thing, is the same thing valid in the invertor? So if I need to summarize, according to the changing parameters, the motors will naturally change, so how should we work in Inventor
blandb
Have you looked into ilogic? Have a series of pick options and have it either place parts based on criteria, or have a base model that will then go and update certain parameters or swap certain parts as needed?
Autodesk Certified Professional
Curtis_Waguespack
@EmreYucel34
Yes, you can swap modeld per a parameter change. See the attached simple Inventor 2024 example. It will swap out the blue component with a different model file based on the parameter selected.
If Rating = "2 HP" Then
	MY_Motor = Components.Add("MY Motor", "Part 2.ipt")
Else
	MY_Motor = Components.Add("MY Motor", "Part 1.ipt")
Constraints.AddInsert("MyInsert", "MY Motor", "Front Edge", "Part 1:1", "Front Edge", axesOpposed := True)
