automatically insert review table
Miguel.CarvajalS34Q6
Hello.
Cordial greeting, for a test that I am doing I need a review table to be automatically inserted in each active drawing sheet, and in the new leaves that are created, as the possibility that the format changes, it is necessary that the location is necessary of the review table this always in the upper right corner of each sheet regardless of the size of the sheet.
I would greatly appreciate your help!
JelteDeJong
this rule will add a revision block to the active sheet
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim position = sheet.Border.RangeBox.MaxPoint
Dim table = sheet.RevisionTables.Add(position)
Dim tableWith = table.RangeBox.MaxPoint.X - table.RangeBox.MinPoint.X
position.X = position.X - tableWith
table.Position = position
Jelte de Jong
Blog: hjalte.nl - github.com
the code works fine, but a new table is not inserted when I create another drawing sheet, I tried to automate it with a trigger, but it does not insert the table in all the sheets, only in the avtiva, in addition to that it is not independent, each value that it is written in the table of one sheet, it is reflected in all the sheets, can you help me with that please
WCrihfield
Hi @Miguel.CarvajalS34Q6.  I think you would simply need to change this one line, like so.
Dim table = Sheet.RevisionTables.Add2(position, True)
It is using the Add2 method, which also has more options available to specify, if you wanted to.
Wesley Crihfield
(Not an Autodesk Employee)
try adjusting the code, in another custom label and the modification table is inserted at the end of the sheet and not the label, how can I solve this event
