Automatically Generate Dimensions in VBA
Is it possible in VBA to automatically generate dimensions on a particular view?
Some told me that retrieve dimensions tool will be applicable. Did someone has a sample code for retrieve dimensions?
PLS HELP!
Thank you!
skyngu
Dim oDrawingView As DrawingView
For Each oDrawingView In oDrawingViews
Call oAllDimensions.Retrieve(oDrawingView)
 Next
Autodesk Inventor Professional 2019
Set sideView= osheet.DrawingViews.addBaseView....
DIm a as GeneralDimensions
Call a.Retrieve(sideView)
Above is the snippet of our program.
What is wrong or lacking in our code?
Error with this code is(Run-time error '91';  Object variable or Wtih block variable not set)
Please help.....thank you!
skyngu
you have not set "a"
check vba help and object browser.
Can help us how to set "a"?
We're just starting using VBA. We still have difficulties regarding to objects.
Thanks in advance.
