Automatically displays a infinite length virtual line in the sketch
lzs013
lzs013
VBA or ILogic: automatically displays a infinite length virtual line in the sketch I need an ilogic or VBA program that can achieve the following function: When you activate a sketch, inventor can automatically display a line that passes through the origin and is at an angle of 45 degrees to the x-axis. The properties of this line are the same as the x-axis and y-axis in the sketch (infinitely long, virtual, unconstrained, can't be seen after exiting the sketch environment)
Can you help me?
lzs013
basnederveen
You can use transientObjects in combination with a few events to achieve this, I think it will be only visual like this though.
Do you want to be able to use this line or is it purely visual?
lzs013
Just visual effect
