'Please try the code as this:
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
Dim oView4 as DrawingView
ExcelFile = "K:\CoOp\STANDARDS\Cover Standards" & ".xlsx"
PN = GoExcel.CellValue(ExcelFile, "Sheet1", "C2")
ViewScale = 1/8
'Ask To create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
oPartDoc = ThisDoc.Document
'Define IDW Template File Location
oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "L:\TEMP.dwg", True)
oSheet = oDrawDoc.Sheets.Item(1)
'Define 2d view bottom Left corner points For four views
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5, 30)
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 1/8,kTopViewOrientation, kHiddenLineDrawingViewStyle, "Default")
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(oPoint1.X+oBaseView.Width, oPoint1.Y-oBaseView.Height)
oView1 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, 1/8)
oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(oPoint1.X-oBaseView.Width, oPoint1.Y-oBaseView.Height)
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, 1/8)
oDrawDoc.SaveAs( "K:\CoOp\STANDARDS\x-204" , False)
oDrawDoc.Close(False)
DrawingDoc = ThisApplication.Documents.Open("K:\CoOp\STANDARDS\X-204" , True)
Dim oCurve As DrawingCurve
oCurve = oDrawDoc.SelectSet(1).Parent
Dim oIntent1 As GeometryIntent, oIntent2 As GeometryIntent
oIntent1 = oDrawDoc.oSheet.CreateGeometryIntent(oCurve, kStartPointIntent)
oIntent2 = oDrawDoc.oSheet.CreateGeometryIntent(oCurve, kEndPointIntent)
Dim oDim As LinearGeneralDimension
Dim oPt As Point2d
oPt = ThisApplication.TransientGeometry.CreatePoint2d(12, 12)
oDim = oDrawDoc.oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPt, oIntent1, oIntent2, kLinearDimensionType)
