Automatic view scale and position rule from center point
Anthony5375F
Anthony5375F
Good afternoon,
I have two codes, one that re-scales and the other that re-positions the drawing view.
Currently if i use the drawing as a template, the drawings vary in size, therefore position and scale sometimes does not work. Could i merge these two codes and rather than position from bottom left corner, position from center point?
Alternatively, look at a better solution?
Here are the two codes along with an attached spreadsheet (Some cells aren't complete yet) as wanted to create a  sheet that controls multiple rules.
Sub Main
	Dim oDoc As DrawingDocument = ThisApplication.ActiveDocument
	''' --------------------------MAGIC DICTIONARY CODE----------------------------------- '''
	' Everything in a Comma Separated Value (.csv) is separated, funnily enough, by a comma
	' FILE CAN'T BE OPEN!
	' Opening CSV file
	' Read lines separately
	' A typical variable line is going to look like this: (10-10, 20-20, 30-30, 10 etc )
	Dim splitChar As String = ","
        Dim csvData As Dictionary(Of Integer, String) = New Dictionary(Of Integer, String)()
        Using reader As New IO.StreamReader("C:\Users\anthony\Desktop\scale_mapping.csv", Text.Encoding.Default)
            Dim line As String = reader.ReadLine
			Dim Index As Integer
			Index = 1
            Do While (Not line Is Nothing) And (Index < oDoc.Sheets.Count)
                Try
                    csvData.Add(Index, line)
                Catch ex As Exception
                    MsgBox("Could not add data from line: " & line)
                End Try
                line = reader.ReadLine
				Index = Index+1
            Loop
        End Using
	For i As Integer = 1 To oDoc.Sheets.Count ' Go through every sheet in document
		oDoc.Sheets(i).Activate ' Activate the sheet
		Dim oSheet As Sheet = oDoc.ActiveSheet ' Reference active sheet
		Dim index As Integer = 4 ' Way to map what view you're on vs the list above
		For Each oView In oSheet.DrawingViews
			' Load the point from our dictionary we made with the csv file
			Dim rowData As String()
			rowData = csvData.Item(i+1).Split(",")
			' This means we get an array of variables like '10-10' etc. We need to split this later using the "-" character
			Dim oScale As Double
			oScale = rowData(index) ' Map current view in loop onto list of numbers above
			Try
				ReScale_View(oView, oScale, oScale) ' Scale accordingly
			Catch
				Logger.Error(oSheet.Name & " has a problematic drawing view.")
			End Try
			index = index + 1 ' Add to the index to go to next number
		Next
'		Try
'			Call RepositionDrawingViewLabels
'		Catch
'			Logger.Error("Error in reposition on " & oDoc.ActiveSheet.Name)
'		End Try
	Next
End Sub
Public Sub ReScale_View (aView As DrawingView, X As Double, Y As Double)
Dim XOrg As Double = aView.Width / aView.Scale
Dim YOrg As Double = aView.Height / aView.Scale
Dim XScale As Double = X / XOrg
Dim YScale As Double = Y / YOrg
aView.Scale = Math.Min(XScale, YScale)
End Sub
Sub Main
	' Opening CSV file
			Index = 1
                Try
                End Try
				Index = Index+1
            Loop
        End Using
		Dim index As Integer = 1 ' Way to map what view you're on vs the list above
			'Try
				oBasePosition = ThisApplication.TransientGeometry.CreatePoint2d() ' Created a point (nominally a Vector) e.g. Vector2d(14,40)
				' Cursed string coercion magic, abandon hope all ye who enter here
				Dim xPos As Integer
				Dim yPos As Integer
				xPos = CInt(rowData(index).Split("|")(0))
				yPos = CInt(rowData(index).Split("|")(1))
				' Terrible code ends... for now
				oBasePosition.X = (xPos/10) + (oView.Width/2)
			    oBasePosition.Y = (yPos/10) + (oView.Height/2)
				Reposition_View(oView, oBasePosition) ' Scale accordingly - passing oView and oBasePosition to the function below
			'Catch
			'	Logger.Error("Cannot place drawing " & oView.ToString & " on Sheet " & oSheet.Name)
			'End Try
		Next
'		Try
'		Catch
'		End Try
	Next
End Sub
Public Sub Reposition_View (aView As DrawingView, aPos As Point2d)
    'Move the baseview to the new position
	'Logger.Info("Moving " & aView.Name & "  from " & aView.Position.ToString & " to " & aPos.ToString)
    aView.Position = aPos
    ' Ensure that the geometry in this view will not move if new geometry is added (and the view size changes as a result)
    ' Note this doesn't prevent a user dragging the view around!
	Try
   		aView.ViewJustification = ViewJustificationEnum.kFixedViewJustification
	Catch
		Logger.Error("Cannot place " & aView.Name)
	End Try
End Sub
JelteDeJong
try it like this:
Sub Main()
	Using reader As New IO.StreamReader("D:\Downloads\scale_mapping.csv", Text.Encoding.Default)
		Index = 1
			Try
			End Try
			Index = Index + 1
		Loop
	End Using
		Dim oSheet As Sheet = oDoc.Sheets(i)
		oSheet.Activate() ' Activate the sheet
		Dim rowData As String() = csvData.Item(i + 1).Split(",")
		For j = 1 To 3
			Dim oView As DrawingView = oSheet.DrawingViews.Item(j)
			' --- Set position ---
			Dim cellPos = rowData(j)
			Dim xPos As Integer = CInt(cellPos.Split("|")(0))
			Dim yPos As Integer = CInt(cellPos.Split("|")(1))
			Dim oBasePosition = ThisApplication.TransientGeometry.CreatePoint2d() ' Created a point (nominally a Vector) e.g. Vector2d(14,40)
			oBasePosition.X = (xPos / 10) + (oView.Width / 2)
			oBasePosition.Y = (yPos / 10) + (oView.Height / 2)
			' --- Set scale ---
			Dim cellScale = rowData(j + 3)
			ReScale_View(oView, cellScale, cellScale) ' Scale accordingly
		Next
	Next
End Sub
Public Sub ReScale_View(aView As DrawingView, X As Double, Y As Double)
	If (aView.ScaleFromBase) Then Return
End Sub
Public Sub Reposition_View(aView As DrawingView, aPos As Point2d)
	Try
	Catch
		Logger.Info("Cannot place " & aView.Name)
	End Try
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
Anthony5375F
Thank you for replying.
It seems to stop on the second page (there are 17) altering page 1 scale
System.ArgumentException: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
at Inventor.DrawingViews.get_Item(Int32 Index)
at ThisRule.Main() in rule: Combined filter/scale, in document Wine cellar.dwg:line 33
at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
Works perfectly on the first page though!
Anthony5375F
Error on line 33 in rule: Combined filter/scale, in document: Wine cellar.dwg
