Automatic sat from spreadsheet
how difficult would it be to set up a spreadsheet to drive a skeletal assembly, then automatically produce a sat file to import into autocad? im thinking that the user will not need to touch inventor, maybe fill in the spreadsheet, save it to a location where a copy of IV will pick it up and spit out the sat file to another location...
this way many users could use a bank of spreadsheets for what they want and get the models into autocad with just 1 IV licence
is this fantasy???
i only want to know if anyone thinks its possible, im not asking anyone to do it (o:
In that case, yes...this is possible!
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 8.4.2.6)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
just out of inerest, how many man hour would it take an epert to set up, (with nice UI's)
I don't really see where any UI would be needed. Wouldn't your Spreadsheet
template, just have the items listed, and the person would change the values
for the items and hit a simple button to create the sat.
The time really depends on how many entrees there were in the spreadsheet.
Are you planning on making assemblies or just parts?
___________________
Kent Keller
www.kwikmcad.com
wrote in message news:5527580@discussion.autodesk.com...
(with nice UI's)
More than likeley just parts, (no need for assemblies because the output is just a dumb representation)
I would need some sort of UI because there could be over 100 parts. i suppose you could run a macro from autocad that would bring up a fileopen box pointing at the excel part folders
