Hi @Anonymous
There's a VBA code posted about this by @Anonymous here:
https://forums.autodesk.com/t5/inventor-ideas/drawings-re-number-detail-amp-section-views/idi-p/6276...
As an iLogic rule it'd look something like this 🙂
Sub Main
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
Dim oView As DrawingView
Dim iter As Long
'check if active document is a drawing
If ThisApplication.ActiveDocument.DocumentType <> kDrawingDocumentObject Then
Exit Sub
oDoc = ThisApplication.ActiveDocument
iter = 1
'Rename detail and section view identifiers on all sheets
For Each oSheet In oDoc.Sheets
For Each oView In oSheet.DrawingViews
If oView.ViewType = kDetailDrawingViewType Or oView.ViewType = kSectionDrawingViewType Then
oView.Name = num2Letter(iter)
iter = iter + 1
If InStr(1, num2Letter(iter), "I") > 0 Or InStr(1, num2Letter(iter), "O") > 0 Or InStr(1, num2Letter(iter), "Q") > 0 Then
iter = iter + 1
Next oView
Next oSheet
End Sub
Public Function num2Letter(num As Long) As String
'converts long to corresponding alpha
'Ex. 1 = A, 28 = AB
remain = num Mod 26
whole = Fix(num / 26)
If num < 27 Then
If remain = 0 Then
num2Letter = "Z"
Else
num2Letter = Chr(remain + 64)
Else
If remain = 0 Then
num2Letter = Chr(whole + 63) & "Z"
Else
num2Letter = Chr(whole + 64) & Chr(remain + 64)
End Function
