Automated Transculent - Surfaces - STEP-file
I need some help. I often get STEP-files where parts are transculent, these assemblies are large.
Can somebody help me coding VBA, so all parts in the assembly are switched off the transculent propertie?
Thanks in advance.
Mike.Wohletz
I think you will find what you are looking for in number 5 of this post.
Turn off Translucent using VBA
I tried the script you mention, before i did the post, but the script doesn't work. In fact it doesn't do anything.
So please who can advice me.
Mike.Wohletz
Try this and see if it works for you..
  Private Sub TranslucentTest()
   Dim oDoc As Inventor.Document
  Set oDoc = ThisApplication.ActiveDocument
          Call TranslucentOff(oDoc)
    End Sub
   Function TranslucentOff(ByVal oDoc As Document)
        If oDoc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            Dim oAssembly As Inventor.AssemblyDocument
            Set oAssembly = oDoc
            Dim oRefDoc As Inventor.Document
            For Each oRefDoc In oAssembly.AllReferencedDocuments
               Call TranslucentOff(oRefDoc)
            Next
        ElseIf oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
            Dim oPart As Inventor.PartDocument
            Set oPart = oDoc
            Dim oWorkSurface As Inventor.WorkSurface
            For Each oWorkSurface In oPart.ComponentDefinition.WorkSurfaces
                If oWorkSurface.Translucent = True Then
                    oWorkSurface.Translucent = False
            Next
    End Function
