Automated print setup Ilogic
HassanLaamiri
HassanLaamiri
I try to automate the print setup with some Ilogic code. Selecting the printer and paper size works fine on the  \\DC01\Kyocera Engineering", except on the "HP Designjet T770 44in HPGL2" the paper size stays on letter.
Does anyone have a solution for this?
Code:
Dim oDoc As DrawingDocument = ThisDoc.Document
For Each oSheet As Sheet In oDoc.Sheets
	If oSheet.Width = 21.0 Then'A4
		oDoc.PrintManager.Printer = "\\DC01\Kyocera Engineering"
		oDoc.PrintManager.PaperSize = kPaperSizeA4
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A4")
	ElseIf oSheet.Width = 42.0 Then 'A3
		oDoc.PrintManager.PaperSize = kPaperSizeA3
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A3")
	ElseIf oSheet.Width = 59.4 Then 'A2
		oDoc.PrintManager.Printer = "HP Designjet T770 44in HPGL2"
		oDoc.PrintManager.PaperSize = kPaperSizeA2
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A2")
	ElseIf oSheet.Width = 84.1 Then 'A1
		oDoc.PrintManager.PaperSize = kPaperSizeA1
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A1")
	Next
Darkforce_the_ilogic_guy
Why not fix that by create a new printer driver on the computer. that are setup to A1. So you do not have to change papir size but simple select the printer ?
WCrihfield
Hi @HassanLaamiri.  I may be wrong, but I don't think that those print settings are being 'saved' individually for each sheet, so I'm guessing whichever sheet is the last one to be checked in that loop, that is likely how the print settings are going to remain when the rule has finished.  And if the last sheet in the loop did not match one of the 4 specific sheet widths, it may not have been set up as expected, since there is no final Else condition.  But if any of them matched the sheet width, I'm not sure why one of those specified paper sizes would not be visible in the dialog afterwards.  Seems a bit odd that different sheets in the same drawing document may be different sheet sizes.  That must make for some pretty interesting printing & publishing routines...like this one.😉
Wesley Crihfield
(Not an Autodesk Employee)
HassanLaamiri
Thanks for the replies, found that the printer only  have available paper ''letter'' in the settings. Looking for a way now to add more paper sizes.
Updated the code..
	If oSheet.Width = 29.7 And oSheet.Height = 21.0 Then'A4
		oDoc.PrintManager.Orientation = kLandscapeOrientation
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A4 Landscape")
	ElseIf oSheet.Width = 21.0 And oSheet.Height = 29.7 Then'A4
		oDoc.PrintManager.Orientation = kPortraitOrientation
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A4 Portrait")
	ElseIf oSheet.Width = 42.0 And oSheet.Height = 29.7 Then 'A3
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A3 Landscape")
	ElseIf oSheet.Width = 29.7 And oSheet.Height = 42.0 Then 'A3
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A3 Portrait")
	ElseIf oSheet.Width = 59.4 And oSheet.Height = 42.0 Then 'A2
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A2 Landscape")
	ElseIf oSheet.Width = 42.0 And oSheet.Height = 59.4 Then 'A2
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A2 Portrait")
	ElseIf oSheet.Width = 84.1 And oSheet.Height = 59.4 Then 'A1
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A1 Landscape")
	ElseIf oSheet.Width = 59.4 And oSheet.Height = 84.1 Then 'A1
		MessageBox.Show(oDoc.PrintManager.Printer & " -> Sheet A1 Portrait")
	Next
