Kindly find the code in the attached part, it has some bugs in dimension creation....do check out....i am too, in the process of learning....
The below code will create
1) Default View, and two Projected View by using "Standard.idw" Template
2) Save the drawing with part file name.
Imports Inventor.ViewOrientationTypeEnum
Imports Inventor.DrawingViewStyleEnum
Dim oDrawDoc as DrawingDocument
Dim oPartDoc as Document
Dim oSheet As sheet
Dim oTG As TransientGeometry
Dim oBaseView As DrawingView
Dim oView2 as DrawingView
Dim oView3 as DrawingView
'Dim oView4 as DrawingView
ViewScale = 3/16
'Ask to create drawing?
dwgQuery=MsgBox("Would you like to Create a drawing for this MODEL?", vbYesNo,"Drawing Selection")
If dwgQuery = vbYes Then
oPartDoc = ThisDoc.Document
modelFullFileName = ThisDoc.ModelDocument.FullFileName
modelFileNamewithoutextentionsion = IO.Path.GetFileNameWithoutExtension(modelFullFileName)
'MsgBox(modelFileNamewithoutextentionsion)
'Define IDW Template File Location
oDrawDoc = ThisApplication.Documents.Add(kDrawingDocumentObject, "C:\Users\Public\Documents\Autodesk\Inventor 2012\Templates\Standard.idw", True)
oSheet = oDrawDoc.Sheets.Item(1)
'Define 2d view bottom left corner points for four views
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(5, 5)
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(5, 30)
oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(30, 5)
oBaseView = oSheet.DrawingViews.AddBaseView(oPartDoc,oPoint1, 3/16,kFrontViewOrientation, kHiddenLineDrawingViewStyle, "Default")
oView2 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint2, kHiddenLineDrawingViewStyle, 3/16)
oView3 = oSheet.DrawingViews.AddProjectedView(oBaseView,oPoint3, kHiddenLineDrawingViewStyle, 3/16)
oDrawDoc.SaveAs(ThisDoc.Path &"\" &modelFileNamewithoutextentionsion &".idw", False)
oDrawDoc.Close(False)
DrawingDoc = ThisApplication.Documents.Open(ThisDoc.Path &"\" &modelFileNamewithoutextentionsion &".idw" , True)
Dim oCurve As DrawingCurve
'oCurve = oDrawDoc.SelectSet(1).Parent
'Dim oIntent1 As GeometryIntent, oIntent2 As GeometryIntent
' oIntent1 = oDrawDoc.oSheet.CreateGeometryIntent(oCurve, kStartPointIntent)
'oIntent2 = oDrawDoc.oSheet.CreateGeometryIntent(oCurve, kEndPointIntent)
'Dim oDim As LinearGeneralDimension
'Dim oPt As Point2d
'oPt = ThisApplication.TransientGeometry.CreatePoint2d(12, 12)
'oDim = oDrawDoc.oSheet.DrawingDimensions.GeneralDimensions.AddLinear(oPt, oIntent1, oIntent2, kLinearDimensionType)
