Automated Centerlines iLogic
I have found parts of some code and written the rest to place automated centerlines on holes and projected parallel axis on all views on a drawing.  But I am having some trouble with the code.  It will place the centerlines on the holes but not the projected parallel axis.  Also, the remove unattached centerlines is not working.  I'm sure I just have a small error somewhere but I am missing it.  Thanks in advance!
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 9446 StartFragment: 314 EndFragment: 9414 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
'Set a reference to the active drawing document
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheets As Sheets
Dim oSheet As Sheet
Dim oViews As DrawingViews
Dim oView As DrawingView
oSheets = oDoc.Sheets
oSheet = oDoc.ActiveSheet
'For each view add centerlines to holes and projection parallel axis
For Each oSheet In oSheets
oViews = oSheet.DrawingViews
    For Each oView In oViews
Dim oCenterline As AutomatedCenterlineSettings
oView.SetAutomatedCenterlineSettings(oCenterline)
       oCenterline.ApplytoHoles  = True
       oCenterline.ProjectionParallelAxis = True
    Dim resultCenters As ObjectsEnumerator
    resultCenters = oView.SetAutomatedCenterlineSettings(oCenterline)
 Next
 Next
' Delete all unattached centerlines
For Each centerLine In oSheet.CenterLines
  If (Not centerLine.Attached) Then
    centerLine.Delete()
Next
wayne.brill
I used your rule and I am getting "Object reference not set to an instance of an object." on this line:
I find that I needed to have this line to avoid the error. (instantiates the oCenterline variable)
oView.GetAutomatedCenterlineSettings(oCenterline)
To get the rule to create the center lines I had to move these lines
Before this line:
Here is the for loop that is working for me:
        'WB added
        'WB moved here
       ' oCenterline.ApplytoHoles  = True
       ' oCenterline.ProjectionParallelAxis = True
'        Dim resultCenters As ObjectsEnumerator
'        resultCenters = oView.SetAutomatedCenterlineSettings(oCenterline)
    Next
 Next
Let me know if the results you get.
Also I find it helpful to have variable names indicate what they are. (naming an AutomatedCenterlineSettings object oCenterLine is confusing to me)
I did not test the problem with deleting the center lines. Please upload a drawing that has center lines that are not attached. (called sick in the API help)
Wayne
Wayne Brill
Developer Technical Services
Autodesk Developer Network
dusan.naus.trz
Hi all,
I had the same problem. thank you for solutions. thumbs up. It could be a service pack or update for 2017?
