Automate Inventor 2015 from Excel with VBA
rfink
rfink
I am trying to open parts and assemblies from Excel using VBA code. Then I want to change some dimensions programatically.
I have no trouble manipulating parts and assemblies ilogic and rules that refer to worksheets that I have generated with VBA, but I would like to change the Inventor parameters directly with VBA from Excel.
I am not trying to write an Add-In using the Inventor 2015 VBA IDE or VB/C# interop in Visual Studio.
I did the exact same thing using SolidWorks, but I am now working with Inventor 2015.
Any help would be appreciated.
Ross
rossano_praderi
Hi Ross,
this is a very basic example on how you can change an "UserParameter".
Sub Parametri()
'On Error Resume Next
Me.Application.WindowState = xlMinimized
    Dim Inv, oDoc As Object
    Dim Param As Inventor.Parameter
    Set Inv = GetObject(, "Inventor.Application")
    If Err.Number <> 0 Then
        MsgBox ("Errore di acquisizione controllo Inventor" & vbCr & "Inventor non attivo")
        Err.Number = 0
        Exit Sub
    Set oDoc = Inv.ActiveDocument
    For Each Param In oDoc.ComponentDefinition.Parameters.UserParameters
      If Param.Name = "test" Then
        If Param.Value = "finito" Then
          Param.Value = "iniziato"
        Else
    Next
End Sub
Of course the parameter "test" have to exist in your PartDocument.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
rfink
Rossano,
Grazie mille!
Ross
rossano_praderi
Prego Ross 🙂
