Autogenerate bitmap-file from parts in Vault
Gwennberg
Gwennberg
Hi
We want bitmap-file on our allready inchecked partfiles in Vault. Would it be possible to start a process there Inventor get and open the file, run a script ,(which I all ready have), close and contiue with next file. Our files are stored in folders i vault with a number serie
BR/Goran
Jacob__with__a__k
Interesting question! here's my attempt to make it work
Not tested yet (no time for that currently), but hopefully you'll now have some basis to start with
The idea: you place both this rule and the script (wich I assume is a separate rule although an external rule should work as well) in a document (ipt, iam, idw doesn't matter), it will loop through all of them: open them: run the script: and close them
be sure to check out all files first! (should be possible automaticly in inventor 2024 but that's a whole different problem 😉 )
I added 2 ways to select all the documents, so choose the one you wish or add your own 😉
(hopefully it works lol)
I'm very interested to see your script for making a bitmap file, if you are interested in sharing it
happy coding!
Sub main
Dim docs As List(Of String)
'get path of all files
	docs = populatedocs1
	'docs = populatedocs2
'loop over all paths in doc
	For Each doc In docs
		Call run_rule_in_docs(doc)
	Next
End Sub
Function populatedocs1 As List(Of String)
'adaptation of code from: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/how-do-i-run-an-external-rule-on-all-files-in-a-folder/td-p/10496739
Dim Folder As New IO.DirectoryInfo("C:\TEMP")
For Each File As IO.FileInfo In Folder.GetFiles("*.ipt",IO.SearchOption.AllDirectories)
	If File.FullName.Contains("OldVersions") = False Then
		populatedocs1.Add(File.FullName)
Next
End Function
Function populatedocs2 As List (Of String)
	populatedocs2.Add("C:\TEMP\doc1.ipt")
	populatedocs2.Add("C:\TEMP\doc2.ipt")
	populatedocs2.Add("C:\TEMP\doc3.ipt")
	populatedocs2.Add("C:\TEMP\doc4.ipt")
	populatedocs2.Add("C:\TEMP\doc5.ipt")
	populatedocs2.Add("C:\TEMP\doc6.ipt")
	populatedocs2.Add("C:\TEMP\doc7.ipt")
	Return populatedocs2
End Function
Sub run_rule_in_docs(sFilePath As String)
'adaptation of code from: https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/run-ilogic-rule-from-an-external-part-file/m-p/6026688#M61524
'name of ilogic rule
Dim oRuleName As String = "TestRule"
'open the file invisibly
oFile =  ThisApplication.Documents.Open(sFilePath, False)
'define the ilogicAutomation
Dim iLogicAuto As Object
iLogicAuto = iLogicVb.Automation
'get the rule
Dim oRule As Object
oRule = iLogicAuto.GetRule(oFile, oRuleName)
'run the rule
iLogicAuto.RunRuleDirect(oRule)
'close the file
oFile.Close
End Sub
Gwennberg
Thanks Jacob
The bitmap script looks like this. I have got it from this forum:
'-------------export BMP file -------------------------------
oPath = "\\server08\pyramid\Pyramid4\BMP\"
Dim oDoc As DrawingDocument
oDoc = ThisDoc.Document
Dim oSheet As Sheet
oSheet = oDoc.ActiveSheet
modeldoc = ThisDrawing.ModelDocument
		If modeldoc Is Nothing Then Exit Sub
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
oViewModelDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oViewModelDocName As String = Left(oViewModelDoc.DisplayName, (InStrRev(oViewModelDoc.DisplayName, ".", - 1, vbTextCompare) - 1))
Dim m_Camera As Inventor.Camera
m_Camera = ThisServer.TransientObjects.CreateCamera()
If oViewModelDoc.DocumentType = kPartDocumentObject Then
  m_Camera.SceneObject = DirectCast(oViewModelDoc, PartDocument).ComponentDefinition
Else
  m_Camera.SceneObject = DirectCast(oViewModelDoc, AssemblyDocument).ComponentDefinition
m_Camera.Perspective = False
Dim m_TO As Inventor.TransientObjects
m_TO = ThisApplication.TransientObjects
m_Camera.ViewOrientationType = Inventor.ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
m_Camera.Fit
m_Camera.ApplyWithoutTransition
ThisApplication.DisplayOptions.NewWindowDisplayMode = DisplayModeEnum.kShadedWithEdgesRendering
ThisApplication.DisplayOptions.Show3DIndicator = False
Dim TumbFilename As String = oPath & oViewModelDocName & ".jpg"
m_Camera.SaveAsBitmap(TumbFilename, 800, 600, m_TO.CreateColor(255,255,255))
