Autofill Drawing View Label
I'm looking to autofill the View label in the Base View dialog box.  in the past, I used some code that adds the words in the Format Text dialog box (see code below).  This however, doesn't change the view name in the model browser.
Thank you for your help.
'Adds View Label
Dim oSSet As SelectSet = ThisDoc.Document.SelectSet
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim oSheet As Sheet = oDoc.ActiveSheet
If oSSet.Count = 0 Then
    MessageBox.Show("You must select a drawing view first", "iLogic")
Exit Sub
'Reference to the drawing view from the 1st selected object
Dim oView As DrawingView = TryCast(oSSet.Item(1), DrawingView)
If oView IsNot Nothing Then
oView.ShowLabel = True
'format the model iproperties
oView.Label.FormattedText = "ISOMETRIC VIEW"
oStringScale = "<Br/><StyleOverride FontSize='0.5'>SCALE <DrawingViewScale/></StyleOverride>"
'add to the view label
oView.Label.HorizontalJustification = HorizontalTextAlignmentEnum.kAlignTextCenter
Else
    MessageBox.Show("The selected object is not a drawing view", "iLogic")
Sergio.D.Suárez
Hi, with the following ilogic code you can change the name of the view that appears in the model browser.
Dim oView As DrawingView= ThisApplication.CommandManager.Pick(16898, "Select View")
oView.Name = oView.Name.ToUpper.Replace(oView.Name,"New Name")
 I hope this helps with your problem. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Thank's perfect. thank you so much
