AutoEdit
AutoEdit
Message 1 of 11
AutoEdit
Help states
AutoEdit
If the macro exists within a part document, this macro is run when a sketch is edited.
I have a AutoEdit sub in my part but the only time it seems to fire is when I have another
document open and switch from it to the one with AutoEdit.
What am I missing?
If help is wrong about AutoEdit, then what event is the proper one to use to catch new
sketches being made?
Kent
Assistant Moderator
Autodesk Discussion Forum Moderator Program
Replies (10)
Message 2 of 11
Hi Kent, nice to meet again.
See Customer files for a sample. This part is starting both macros when creating a new part from it, also when it is the first document that's get opened.
The only limitation i could found is that it must be a document macro.
Anton
Message 3 of 11
Hi Anton
Good to see you around again. 8^)
Unless I am reading this wrong??
"AutoEdit
If the macro exists within a part document, this macro is run when a sketch is edited."
For me it doesn't fire when you edit a sketch like it says it will???
Kent
Assistant Moderator
"avbuiten" wrote in message news:f186858.0@WebX.maYIadrTaRb...
> Anton
Message 4 of 11
My apologize; it does fire off when the document is edited, but indeed not when (any) object is edited.
Something for Autodesk to kook at.
Greetings,
Anton
Message 5 of 11
Thanks, I thought I was going crazy(er)
I am sure this is something I should know, but what event would I use to watch for a
sketch being edited or created?
Kent
Assistant Moderator
"avbuiten" wrote in message news:f186858.2@WebX.maYIadrTaRb...
object is edited.
> Greetings,
> Anton
Message 6 of 11
What kind of programming did you had in mind.
I found no ordinary PartDocument events to handle this (except the AutoEdit, but this doesn't seems to work).
So i guess the only way to handle this is with a separate VB program, watching the (change of) ActiveEditObject in the current document.
Message 7 of 11
It isn't a real big deal, but one of the master sketches I am working on almost every new
sketch I have to project the origin point. I figured maybe I could do it automatically
every time a new sketch was started in this file.
I suppose the easy way out is to have a button that starts a new sketch and projects the
origin, but I am so used to typing S to start a sketch I would probably forget to use it
half the time.
Kent
Assistant Moderator
"avbuiten" wrote in message news:f186858.4@WebX.maYIadrTaRb...
Message 8 of 11
Kent,
Do you have a VB6 compiler? If so see customer files/AutoEdit. This is just a simple example intercepting the name of the ActiveEditObject in the current document.
Write you're own code in between.
Anton
Message 9 of 11
Thanks for the efforts Anton. I think for the time being I will just stick with manually
projecting the origin each time.
Hopefully Events will get a little more robust in the future. 8^)
Kent
Assistant Moderator
"avbuiten" wrote in message news:f186858.6@WebX.maYIadrTaRb...
> Kent,
> Anton
Message 10 of 11
Kent,
It is a known problem and is being debated on what the behavior should be.
-Thilak
"Kent Keller" wrote in message
news:FA48B852B41B356CE1CEEAB02EF6BFCA@in.WebX.maYIadrTaRb...
> Hi Anton
> "AutoEdit
sketch is edited."
> Kent
> Assistant Moderator
creating a new
> > Anton
Message 11 of 11
Thanks Thilak
I vote for just like help says, but I guess if I knew all the options my
vote might be different 8^)
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
"Thilak" wrote in message
news:91285BABE7EED301150B652AB2A050FF@in.WebX.maYIadrTaRb...
> Kent,
be.
> -Thilak
