autodesk Shell Extensions causing poor desktop performance.
JNielson65
JNielson65
I am using Windows 10 pro and its a fresh install (about a month old now). I am running a Samsung 970 EVO 500GB (NVME SSD) and a 1TB 860 QVO (SATA SSD). After the fresh install but BEFORE installing inventor, file explorer is snappy and responsive. After installing inventor, I right click on a drive on the side and it takes a good 4-5 seconds to respond with the "right click" menu. I disable every Autodesk shell extension (using shellexview) and the problem disappears. I would like to get these working again but i have kept them disabled because it seems they are still broken (atleast for me).
Any Ideas?
Yong.Jing
Autodesk Support
Autodesk Support
@JNielson65  As you have not talked about the RAM on you desktop, I am not sure the long time , please check the system requirement of Inventor.
On the otherside, please follow About InfoCenter  to check the online setting with Inventor and turn off all internet configuration.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
JNielson65
Computer is currently running 12 GB of DDR4. CPU: i7-6700 HQ. GPU: GTX 1060 (Laptop Model). Most of my assemblies are small (usually 50 parts or less) and i do not have an issue using the software. It is more so how the shell extensions (The "shortcuts" that show up when you right click.) have negatively impacted my computers performance. When i disable the autodesk shell extensions, the "slow" right click problem goes away. This behavior persists even on a cold boot with inventor not running. I have attached an image showing what i disabled and also included a picture of my "right click". I will note that the version number by the shell extension changed? maybe i should renable them and see if it still does it.
EDIT: The problem is gone. All autodesk extensions are enabled and there is no "slow right click" problem. It's fixed.
