Autodesk Inventor Vb.Net AddIn - Force version of Dxf output
isocam
isocam
Can anybody help?
I have the following code, taken from a Vb.Net "Addin".
Dim extrusion As ExtrudeFeature = oCompDef.Features.ExtrudeFeatures.Item(1)
Dim sketch As Sketch = extrusion.Definition.Profile.Parent
sketch.DataIO.WriteDataToFile("DXF", DxfFileName)
Does anybody know how I can change the above to export a Dxf file to a different version of AutoCAD, for example, save to an AutoCAD 2007 dxf file?
Many thanks in advance!
Darren
Dev_rim
Hi Darren
Can you I am not sure but i looked in to the API Help
So with this information maybe it can be work:
sketch.DataIO.WriteDataToFile("DXF?AcadVersion=2007", DxfFileName)
Regards
Devrim
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
