Autodesk inventor library automatically create part
k.grigoriou
k.grigoriou
Hi!
I'm trying a lot of days now to find an easy way to create a lot parts from the library
for example i want to create pipe in every available diameter inside the library for a specific length .
how i can do it with to doing it manually.
Gabriel_Watson
The quick way is making iParts:
But the right way, for a proper library, is using the Content Center with a custom family:
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-ECDD0F38-2706-4165-937D-D4E2A8750C4C
CGBenner
@k.grigoriou
Are you trying to quickly generate every component from a specific Content Center family?  I'm not aware of any quick way to do this with standard tools, but perhaps there could be a custom solution made with iLogic?
Chris Benner
k.grigoriou
@CGBenner
yes this is exactly what I want to do i trying to find a solution with ilogic but its to complicated for me.
k.grigoriou
i found one solution with ilogic is not so sophisticate it but is working
i create one new list inside the library with the name "NUMBER"
For i As Integer = 1 To 400
    Dim partNumber As String = i.ToString()
    Dim ASTM_A106_Pipe_Seaml = Components.AddContentCenterPart("occName",
                                                               "Tube & Pipe:Conduits:Pipes",
                                                               "the Family name",
                                                               {"NUMBER", partNumber})
Next
CGBenner
@k.grigoriou
Thanks for clarifying.  I am going to move this thread over to the iLogic forum where someone might be able to help you with this rule.  Good luck!
Chris Benner
