Auto Sort on Update in Partslist in idw
dominiek_vanwest
Message 1 of 10
dominiek_vanwest
The code for sorting a Partslist in an idw is something like this:
  Partslist.Sort("ITEM", False, Nothing, Nothing, Nothing, Nothing)
However, I don't see an option to check the 'Auto Sort on Update' checkbox.
How can I do this?
Thanks in advance,
Dominiek
Replies (9)
Message 2 of 10
BrandonBG
I can't find it either.
There is "DrawingPartsListUpdateCtxCmd" in the command manager which might be useful, but I'm not sure what the context is.
Have you tried setting up a trigger to re-sort the parts list table when something changes?
BrandonBG
Message 3 of 10
dominiek_vanwest
You mean with iLogic?
That might be possible, but I have a few hundred standard drawings to adjust....
Also, that will make the file a bit larger I guess.
Dominiek
Message 4 of 10
BrandonBG
You could write an external rule that wouldn't increase the file size.
Brandon
Message 5 of 10
Vladimir.Ananyev
Agree with Brandon.
External iLogic rule would be the simpliest way to run PartsList.Sort function in drawings that wouldn't increase the file size.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Message 6 of 10
dominiek_vanwest
Sorry for not replying back immediately, I was 2 weeks on holiday.
I'm not sure how to do it with iLogic. In my application, I make that drawing with that PartsList, but I also immediately check it in to the Vault.
How can I get the iLogic rules to run in between my programming code? And how would the iLogic rules look like?
Thanks in advance,
Dominiek
Message 7 of 10
Vladimir.Ananyev
You need three lines of code to execute Inventor command:
VBA:
Dim ctrl As ControlDefinition
Set ctrl = ThisApplication.CommandManager.ControlDefinitions("DrawingPartsListUpdateCtxCmd")
ctrl.Execute
In iLogic rule you should remove 'Set' from the second line.
Here is the good overview on running Inventor commands using the API
http://modthemachine.typepad.com/my_weblog/2009/03/running-commands-using-the-api.html
Vladimir Ananyev
Message 8 of 10
dominiek_vanwest
Thank you for the reply.
But now I get a message in Inventor: Parts list may contain explicit user overrides that are not in a frozen state. Processing an update now will remove explicit user overrides.
And if I click OK I do not see the checkbox 'Auto Sort on Update' checked.
How can I avoid the message showing and the checkbox checked?
Thanks in advance,
Dominiek
PS: Your info did help for something else, for getting my view to Isometric view. I used to do it with Sendkeys("F6"), but if the screen was not active, it would not work. But with your info it works everytime now. Thanks!
Message 9 of 10
Vladimir.Ananyev
Could you restore removed explicit user overrides using referenced BOMRow data?
Vladimir Ananyev
Message 10 of 10
dominiek_vanwest
What do you mean exactly?
