Auto-Sort Bill of Material
Hi Everyone,
I'm trying to create a rule that will do the following;
  1. Sort by Item # in Bill of Material
  2. Renumber Item # in Bill of Material
  3. Sort by Item # in Parts List (but not override the BoM Item #)
  4. Auto Update in Parts List
I created the code below but, I am running into an "object not defined" error.  I'm not confident this is the only error that will come from this though.  If anyone could take a look and let me know where I am going wrong, I would appreciate it.
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
'BOM RENUMBER
' Set a reference to the BOM
Dim oBOM As BOM
	oBOM.StructuredViewFirstLevelOnly = False
	oBOM.StructuredViewEnabled = True
	Dim oStructuredBOMView As BOMView
    oStructuredBOMView = oBOM.BOMViews.Item("Structured")
Call oStructuredBOMView.Renumber(1, 1)
'PART LIST SORT
oPartsList1 = oDrawDoc.ActiveSheet.PartsLists.Item(1)
oPartsList1.Sort2("ITEM", 1, "DESCRIPTION", 1, "SIZE", 1, AutoSortOnUpdate, True)
Sergio.D.Suárez
Hi, this is a code that used at a time to add materials. I hope I can serve you. regards!
Private Sub Main()
	Dim tip As Document = ThisDoc.Document
	If tip.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject  Then
	    Delete_BOM
		Add_BOM
	Else
		MessageBox.Show("Open Drawing Document", "Insert Bill of materials")
End Sub
Sub Delete_BOM
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
For Each oPartList As PartsList In oSheet.PartsLists
	On Error Resume Next
	oPartList.Delete
Next
End Sub
Sub Add_BOM
	Dim oDrawingDoc As DrawingDocument
	oDrawingDoc = ThisApplication.ActiveDocument
	Dim oSheet As Sheet
	oSheet = oDrawingDoc.ActiveSheet
	Dim oDrawingView As DrawingView
	oDrawingView = oSheet.DrawingViews(1)
	Dim oBorder As Border
	oBorder = oSheet.Border
	Dim oPlacementPoint As Point2d
	xrev = oBorder.RangeBox.MaxPoint.X
	yrev = oBorder.RangeBox.MaxPoint.Y
	oPlacementPoint = ThisApplication.TransientGeometry.CreatePoint2d(xrev, yrev)
	Dim oPartsList1 As PartsList
	oPartsList1 = oSheet.PartsLists.Add(oDrawingView, oPlacementPoint, 46594)
'kFirstLevelComponents 46593 First level components.
'kPartsOnly 46594 Parts only.
'kStructured 46593 Structured first level components.
'kStructuredAllLevels 46595 Structured all components.
	oPartsLis1t = oDrawingDoc.ActiveSheet.PartsLists.Item(1)
	Dim myparam As String
	myparam = InputBox("Enter the name of the column to sort", "Sort Bill of materials", "DESCRIPTION")
	oPartsList1.Sort(myparam)
	oPartsList1.Renumber
	oPartsList1.Style.UpdateFromGlobal
	'oPartsList1.Style = oDrawingDoc.StylesManager.PartsListStyles.Item("Select Style BOM")
	'Relocate in lower position
	Dim newposition As Point2d
	newposition = oPartsList1.Position
	newposition.Y=oBorder.RangeBox.MinPoint.Y + 2.2 + (oPartsList1.RangeBox.MaxPoint.Y - oPartsList1.RangeBox.MinPoint.Y)
	oPartsList1.Position = newposition
	InventorVb.DocumentUpdate()
End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
rhasell
Hi
You have mixed the BOM and Parts list in one rule.
These are are in separate environments, that one of the reasons why it is generating an error.
The BOM is in the Assembly environment, and the parts list in the drawing environment.
Here is some working code for you.
You just need to add/adjust the sort criteria.
'Dim oDrawDoc As DrawingDocument
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
'BOM RENUMBER
Dim oBOM As BOM
oBOM = oDoc.ComponentDefinition.BOM
	'Call oStructuredBOMView.Sort("BOM Structure",True ,"TYPE",True ,"Stock Number",True)
	Call oStructuredBOMView.Sort("Description", True)
However, I have been down this road before, and thanks to a lot of help from Curtis, I have found that sorting the Parts list (In the drawing environment) is way better. It is more predictable and consistent.
The reason for doing so was due to the fact that if you try an sort the BOM with more than one criteria, it never worked properly.
Reg
2026.1
rhasell
Hi
Here is a snippet of my code used to sort the Parts List
Once again, you need to set the Criteria, and it is important that column labels exist in the physical Parts List.
oPartsList1.Sort("COST CENTER",1,"TYPE", 1, "STOCK NUMBER", 1) ' Sort
oPartsList1.SaveItemOverridesToBOM 'Save Back the the assembly
Reg
2026.1
Thank you for your help.  When I ran this rule I was given the following error.
Error in rule: Rule0, in document: TWSWS-201-L.idw
Unable to cast COM object of type 'Inventor._DocumentClass' to interface type 'Inventor.AssemblyDocument'. This operation failed because the QueryInterface call on the COM component for the interface with IID '{29F0D465-C114-11D2-B77F-0060B0F159EF}' failed due to the following error: No such interface supported (Exception from HRESULT: 0x80004002 (E_NOINTERFACE)).
Unfortunately, my hands are tied when it comes to using the BOM instead of the parts list.
rhasell
Hi
The reason for the failure is because you ran the code from within a drawing. The code is meant to be run in the Assembly environment. If you run it from an assembly it will work. (Also the rule currently only works with a Structured BOM, is that what you wanted?)
If you run the second snippet of code that I posted from the drawing environment ("TWSWS-201-L.idw") that will work. If you do not want to write the changes back to to the assembly, then just comment out the last line line. (This rule will run on both Structured and Parts only)
Reg
2026.1
Thank you for your help!  This is exactly what I needed.
