Auto Numbering
Auto Numbering
timothy_berg
Message 1 of 12
Auto Numbering
timothy_berg
Looking for some iLogic help with creating sequential numbers for subassy's and parts, an example would look something like this:
MASTER ASSY - 001
  SUB ASSY - 002
   PART - 005
   PART - 006
   PART - 007
  SUB ASSY - 003
   PART - 008
   PART - 009
   PART - 010
   PART - 011
  SUB ASSY - 004 (etc.) rule would count all sub assys and number according to the qty of sub assys in the master assy
   PART - 012
   PART - 013 (etc.) rule would number all parts starting with the next number in sequence after the count of sub assys
the "000" numbers are than used for CNC tags, drawing numbers, etc., I all ready have the CNC and drawing number part figured out, I would like to automate the numbering sequence, if possible.  I'm sure there is a thread where this is solved or close enough that i can figure it out, but I haven't had any success finding it.
Replies (11)
Message 2 of 12
NachoShaw
Hi
In code, you would to get the file type by looping the ReferencedFiles and have 2 counters
Dim PartCounter As Double
Dim AssyCounter As Double
PartCounter = 000
AssyCounter = 000
Select Case oDoc.Document.Filetype
Case is kAssembly
oDoc.Name = "Assy_" & AssyCounter
AssyCounter = AssyCounter + 1
Case is kPart
oDoc.Name = "Part_" & PartCounter
PartCounter = PartCounter + 1
Enda Select
The harder part is renaming everything from inside an Assembly. You also can't rename an open assembly. Unless of course you are doing everything to a closed assembly
Let me know how you get on please? My code is from memory and I can take a proper look tomorrow
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
Message 3 of 12
timothy_berg
Thanks for the response, I did try to use this code and I got an error on every line.
Message 4 of 12
Just wondering if you were able to work out the bugs from this code, I tried to use it but I am also getting quite a few errors.
Message 5 of 12
NachoShaw
Hey
I hadn't looked because the thread went cold but I can look tomorrow. How are you numbering them? From inside the Assy or though apprentice? Or are you just populating the part numbers etc?
It should be easy enough. You want to do something like:
Get a count of the sub assemblies from top level
Create a dim to hold the count
Loop Assy and check it's type
Create a counter for Assy
Create a counter for part
If it's a part, name = PartCounter+ 1
If it's an Assy, name = AssyCounter +1
Etc etc
If you can give some examples, I can write up a routine (based on your naming method)
Nacho
Nacho
Message 6 of 12
I am wanting sequential numbering at the beginning of part numbers only. Is this something that can be added to existing parts? The software that we are using to send parts to the router is pulling from the file name and we need a 3 digit code at the beginning.
001_Left_Side
002_Right_Side
003_Top
004_Bottom
Message 7 of 12
NachoShaw
So you only need to update the I properties Part Number?
Yes it can be done. To be clear, assemblies are numbered for example: 5 sub assemblies.
Top level = 001
Each sub, 002, 003 etc
Part numbers 006 onwards
Nacho
Message 8 of 12
NachoShaw
Is there anything in the Iproperties that state the left, right, top etc?
As a question, these are not unique numbers compared to another assy that will get the same numbering method. How are you controlling that?
Nacho
Message 9 of 12
The software that we are using is picking up the file name located in the general tag of iproperties. It is not referencing the part number.
It would not be a problem if the assembly and sub assembly also had numbers. The file names that we are currently using has a code which is specific to the client and item we are producing (ex. 001_ABC_123_45_Left_Side) having the sequence repeat per assembly is actually what I was hoping for.
Message 10 of 12
timothy_berg
that would be perfect i do not need any other iProperties populated in the sequence and I'm assuming that i would open the master assy and run this rule?
Message 11 of 12
NachoShaw
Hi
I hadn't realised there were 2 people here, thought I was talking with the option.
Morrissey
Yes, you can loop through the references and change the part number to include the digits at the front.
I'll read thoroughly tomorrow on my pc and get something together by friday
Nacho
Nacho
Message 12 of 12
timothy_berg
Just wondering if this has been solved.
