Auto fill-in of prompted entry text
I am wanting to know if it is possible to use iLogic to copy a value from iProperties into a Field text.
As I am not a programmer I can not easily come up with the syntax.
The field text is located in the title block and is for the sheet scale pulled from the base view of the sheet.
I am wanting to do this so the sheet scale is no longer hand entered. There is too much room for error (sausage fingers) for this method to continue.
What I am trying to figure out is: field text."dwg scale" = custom iproperties. "Scale #"
Below is the code that I have. The line of code (in red) is just wrong.
Any ideas? maybe the code to accomplish this?
Any other ideas how to automate this to remove the possibility of human error?
Any assistance would be greatly appreciated.
' Sheet scale from base view
Dim odrawdoc As DrawingDocument
odrawdoc = ThisApplication.ActiveDocument
customPropertySet = odrawdoc.PropertySets.Item("Inventor User Defined Properties")
'i is a counter so that each cycle through this it increments i
For i = 1 To odrawdoc.Sheets.Count
'Make sure the desired property exists
Try
  prop = customPropertySet.Item("Scale" + Str(i))
Catch
'Assume error means not found and create custom iProperty
 customPropertySet.Add("", "Scale" + Str(i))
End Try
'set value of custom iProperty = base view scale for the sheet
Try
iProperties.Value("Custom", "Scale" + Str(i)) = odrawdoc.sheets.item(i).DrawingViews.Item(1).ScaleString
Catch
End Try
Next i
InventorVb.DocumentUpdate()
Try
odrawdoc."Sheet:1".TitleBlock.Value("DWG SCALE") = iProperties.Value("Custom", "Scale 1")
Catch
End Try
Here is an "update" line of code to replace my previous line that was highlighted in red.
This still does not work but it does not cause errors or warnings when closing the iLogic editor.
'set base view scale to title block field text
Try
odrawdoc.sheets.item(1).TitleBlock.PropertyField.Value("Prompted Entry", "DWG SCALE") = iProperties.Value("Custom", "Scale 1")
Catch
End Try
To clarify, if it is needed, I am just trying to write a Custom iProperty to a prompted entry field in my title block.
Again any and all assistance wouuld be greatly appreciated.
