look here: https://forums.autodesk.com/t5/inventor-customization/ilogic-coding-to-create-automated-drawing/m-p/...
to create a balloon with VBA, this is the code from the Inventor help:
Public Sub CreateBalloon()
' Set a reference to the drawing document.
' This assumes a drawing document is active.
Dim oDrawDoc As DrawingDocument
Set oDrawDoc = ThisApplication.ActiveDocument
' Set a reference to the active sheet.
Dim oActiveSheet As Sheet
Set oActiveSheet = oDrawDoc.ActiveSheet
' Set a reference to the drawing curve segment.
' This assumes that a drwaing curve is selected.
Dim oDrawingCurveSegment As DrawingCurveSegment
Set oDrawingCurveSegment = oDrawDoc.SelectSet.Item(1)
' Set a reference to the drawing curve.
Dim oDrawingCurve As DrawingCurve
Set oDrawingCurve = oDrawingCurveSegment.Parent
' Get the mid point of the selected curve
' assuming that the selection curve is linear
Dim oMidPoint As Point2d
Set oMidPoint = oDrawingCurve.MidPoint
' Set a reference to the TransientGeometry object.
Dim oTG As TransientGeometry
Set oTG = ThisApplication.TransientGeometry
Dim oLeaderPoints As ObjectCollection
Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
' Create a couple of leader points.
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 10))
Call oLeaderPoints.Add(oTG.CreatePoint2d(oMidPoint.X + 10, oMidPoint.Y + 5))
' Add the GeometryIntent to the leader points collection.
' This is the geometry that the balloon will attach to.
Dim oGeometryIntent As GeometryIntent
Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
Call oLeaderPoints.Add(oGeometryIntent)
' Set a reference to the parent drawing view of the selected curve
Dim oDrawingView As DrawingView
Set oDrawingView = oDrawingCurve.Parent
' Set a reference to the referenced model document
Dim oModelDoc As Document
Set oModelDoc = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
' Check if a partslist or a balloon has already been created for this model
Dim IsDrawingBOMDefined As Boolean
IsDrawingBOMDefined = oDrawDoc.DrawingBOMs.IsDrawingBOMDefined(oModelDoc.FullFileName)
Dim oBalloon As Balloon
If IsDrawingBOMDefined Then
' Just create the balloon with the leader points
' All other arguments can be ignored
Set oBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
Else
' First check if the 'structured' BOM view has been enabled in the model
' Set a reference to the model's BOM object
Dim oBOM As BOM
Set oBOM = oModelDoc.ComponentDefinition.BOM
If oBOM.StructuredViewEnabled Then
' Level needs to be specified
' Numbering options have already been defined
' Get the Level ('All levels' or 'First level only')
' from the model BOM view - must use the same here
Dim Level As PartsListLevelEnum
If oBOM.StructuredViewFirstLevelOnly Then
Level = kStructured
Else
Level = kStructuredAllLevels
' Create the balloon by specifying just the level
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , Level)
Else
' Level and numbering options must be specified
' The corresponding model BOM view will automatically be enabled
Dim oNumberingScheme As NameValueMap
Set oNumberingScheme = ThisApplication.TransientObjects.CreateNameValueMap
' Add the option for a comma delimiter
oNumberingScheme.Add "Delimiter", ","
' Create the balloon by specifying the level and numbering scheme
Set oBalloon = oActiveSheet.Balloons.Add(oLeaderPoints, , kStructuredAllLevels, oNumberingScheme)
End Sub
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated
Succes on your project, and have a nice day
Herm Jan
