Message 1 of 1
AttributeSet.GetReferenceKey
Product: Autodesk Inventor 2019
Programming Language: VBA
Application Programming Interface (API): Inventor API
I am trying to use the "GetReferenceKey"-Method on a AttributeSet.(Found at Inventor API Help "AttributeSet Object"
) I never had troubles using this method on other objects. But when I try to bind the key back on a object it always failes with AttributeSets. I attached a short Code-Example which shows the problem.
Am i using the method wrong or is this an API-Bug?
Many thanks for your help.
Code Example:
Sub AttributeSet_GetReferenceKey_Test()
Dim oApp As Inventor.Application
Set oApp = ThisApplication
Dim oDoc As Inventor.Document
Set oDoc = ThisApplication.ActiveDocument
Dim myAtSet As Inventor.AttributeSet
Set myAtSet = oDoc.AttributeSets.Add("TestAttributeSet", False)
Dim RefKeyBy() As Byte
Dim KeyCon As Long
Dim KeyConBy() As Byte
KeyCon = oDoc.ReferenceKeyManager.CreateKeyContext()
Call myAtSet.GetReferenceKey(RefKeyBy, KeyCon)
Call oDoc.ReferenceKeyManager.SaveContextToArray(KeyCon, KeyConBy)
'Set myAtSet = Nothing
Dim myObject As Variant
Dim myContext As Variant
Dim CanBind As Boolean
KeyCon = oDoc.ReferenceKeyManager.LoadContextFromArray(KeyConBy)
CanBind = oDoc.ReferenceKeyManager.CanBindKeyToObject(RefKeyBy, KeyCon, myObject, myContext)
If CanBind = True Then
Debug.Print ("Das Gesuchte Objekt wurde gefunden.")
Else
Debug.Print ("Das Gesuchte Objekt wurde nicht gefunden.")
‘Set myObject = oDoc.ReferenceKeyManager.BindKeyToObject(RefKeyBy, KeyCon)
End Sub
