Attribute Set
Attribute Set
Message 1 of 1
Attribute Set
Hi
I have used the dynamic attribute sample provided with the Inventor API. But I had one problem. When I assigned the Attribute to one of the object like face of the part and if that object i.e. Face is changed by adding a hole on that face then I was not been able to retrieve the Attribute set value which I assigbed previously. For this I contacted to the Autodesk support and thy provided a sample for reading the attribute set by opening the Attributesetmanager.
But at present I am assigning a attribute to the feature of the part and am interest in retrieving that attribute at the later stage but am unable to do that.
Is the syntax changes from object to object how the attribute will be read.
Can any body help me out In this problem. If I am doing any stupid thing then You may laufg on me.
Manoj
Replies (0)
