Attaching Style to Template
Is there a way to attach a style (.styxml) to a template that I created?
I want to be able to just open the template without having to import the .styxml every time I start a new drawing.
Thanks.
kennyj
Have you tried adding your style to the Project?
Open the Projects and under "Project" select "Included file" and add here.
The other option would be to add it to your style library.  once added, save the drawing into your template folder so you can choose that file as an option.
Hope that helps,
Kenny
