Ataching leader note to sketched symbol in drawing
omartin
Message 1 of 8
omartin
Trying to attach a leader note to a sketched symbol, but I get errors when adding geometry intent (commenting out the line adding the intent will add the leader but it is not attached)
If I were just to add a leader manually to the sketchedsymbol and move around the symbol, this leader is attached as expected.
from this manual leader I inspected the properties on the leaderNode with the attachedEntity property and tried to copy the values when creating the geomtryIntent, but did not work.
I tried a bunch if different things but here is the simplest version I would think should of worked but I get an, "Expecting object to be local" error.
other times I would get a, "Method 'Add' of object 'LeaderNotes' failed"
I am just working in the vb editor right now on IV2023
I got some clues form topics such as below: where they talk about hidden leaders to attach to, but cant seem to find out how where to find these nodes to attach to:
Insert Drawing Sketched Symbol Behind DrawingView
Leader note/node from Sketched Symbol
In my sketchedSymbols defintion I moved the point where I am trying to attach to to 0,0 in its sketch space
any ideas greatly appreciated
Public Sub AddLeaderNotetestxx()
    Dim trg As TransientGeometry
    Set trg = ThisApplication.TransientGeometry
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.activeDocument
    Dim sk As SketchedSymbol
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    Set sk = oActiveSheet.SketchedSymbols(1).leader.Parent
    Dim oMidPoint As Point2d
    Set oMidPoint = sk.Position
    Dim oLeaderPoints As ObjectCollection
    Set oLeaderPoints = ThisApplication.TransientObjects.CreateObjectCollection
    Dim oGeometryIntent As GeometryIntent
    Call oLeaderPoints.Add(trg.CreatePoint2d(oMidPoint.x + 5, oMidPoint.Y + 5))
    Call oLeaderPoints.Add(trg.CreatePoint2d(sk.Position.x, sk.Position.Y + 1.1))
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(sk.leader.Parent, trg.CreatePoint2d(sk.Position.x, sk.Position.Y + 1.1))
    Call oLeaderPoints.Add(oGeometryIntent)
    Dim sText As String
    sText = "API Leader Note"
    Dim oLeaderNote As LeaderNote
    Set oLeaderNote = oActiveSheet.DrawingNotes.LeaderNotes.Add(oLeaderPoints, sText)
End Sub
Was my reply Helpful ? send a Kudos or accept as solution
Replies (7)
Message 2 of 8
Curtis_Waguespack
@omartin, I'm not completely sure I understand the request, but here is an example that adds leaders to an existing symbol.
Hope that helps, Curtis
oDrawDoc = ThisApplication.ActiveDocument
Dim oSegment As DrawingCurveSegment
oSegment = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingCurveSegmentFilter, "Select an edge")
If oSegment is nothing then exit sub
Dim oSymbol As SketchedSymbol
oSymbol = oActiveSheet.SketchedSymbols(1)
Dim oMidPoint As Point2d = oSymbol.Position
Dim SelectPt As Point2d = oSegment.Parent.MidPoint
oLeaderPoints.Add(oSymbol.Position)
oGeometryIntent = oActiveSheet.CreateGeometryIntent(oSegment.Parent)
'oSymbol.LeaderClipping = True
'oSymbol.LeaderVisible = True
Try
	oSymbol.Leader.AddLeader(oLeaderPoints)
Catch
	'if the symbol already has a leader
	oSymbol.Leader.RootNode.AddLeader(oLeaderPoints)
End Try
Message 3 of 8
omartin
Hey @Curtis_Waguespack thanks for the reply!!
I was actually referring to adding a separate LeaderTextNote, that is attached to the sketchedSymbol (so when the symbol moves the note moves)
in the pic, the sketchedSymbol is the 25 with the line in the middle, the "im attached" LeaderNote, is a note I placed manually to try and see how it was attached,  for testing purposes.
so the drawing intent is somehow attached to the sketchedSymbol instead of a drawingCurve.
Hope that is a better explanation. I attached a drawing as well
Message 4 of 8
WCrihfield
Hi @omartin.  I would suggest just specifying the SketchedSymbol object as the first input for the CreateGeometryIntent method, instead of SketchedSymbol.Leader.Parent.  Then, for the second input into that method, which needs to be a point on that object's geometry, we may have some options.  If the SketchedSymbol had a visible leader, then we could likely use the 'position' of one of the leader nodes.  But if it does not have a leader, and maybe not even attached to anything, then we may have to fall back to getting the actual geometry included within the symbol.  To do that, we would have to step down into its SketchedSymbolDefinition, then the DrawingSketch associated with that definition.  Then find the piece of geometry (for example a SketchLine), then get the StartPoint or EndPoint of that Line, then the Point2D associated with that SketchPoint.  As long as it is 'real' visible geometry.  Then, I'm guessing that we would likely have to translate that point from sketch space to sheet space, which could be done with the DrawingSketch.SketchToSheetSpace method.
Wesley Crihfield
(Not an Autodesk Employee)
Message 5 of 8
omartin
Right, let me give  it a shot with the sketch definitions and DrawingSketch.SketchToSheetSpace
Message 6 of 8
omartin
Hey @WCrihfield  thanks for replying!
Im still getting the expecting object to be local error.
in the skecthedSymbol's sketch definition space, the point I'm connecting to is @0,0
when I use the  DrawingSketch.SketchToSheetSpace () I still get 0,0 returned
But even If I hard code the coordinates (by taking them from the note that I manually added) it still does not work
I also tried to add a leader, and use the root node but no luck...
according to the docs, it lists sketchedEntites as valid input for the createIntent function but not sketchedSymbols.
I also tried using the sketchline, with varioous points but a no go.
Maybe it is just not possible or a bug ...But Why is works manaully 😕
    Dim ds As DrawingSketch
    Set ds = sk.Definition.Sketch
    Dim sl As SketchLine
    Set sl = ds.SketchLines(1)
    Set oMidPoint = ds.SketchToSheetSpace(sl.Geometry.StartPoint)
    Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(sk, sk.leader.RootNode.Position)
'also tried
' Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(sk, omidpoint)
' Set oGeometryIntent = oActiveSheet.CreateGeometryIntent(sk, trg.CreatePoint2d(sk.Position.x, sk.Position.Y + 1.1) (this is the start point of the line on the sheetpace)
    Dim sText As String
End Sub
Message 7 of 8
WCrihfield
Hi @omartin.  I was just making educated guesses at what might work above, without actually trying it myself at the time, due to lots of things going on.  I thought I remembered this being possible, but its very possible I was wrong.  I just got to a slow point at work, so I tried out several things myself, but couldn't make it 'attach' to the sketched symbol either.  When inspecting the GeometryIntent of the manually placed LeaderNote that is properly attached, the GeometryIntnent.IntentType = kPoint2dIntent, but then the GeometryIntnent.Geometry property also had a value of type "SketchedSymbol", which allows it access to the properties of the SketchedSymbol.  So, the user interface tools allow us to make this connection / attachment, but it is all handled automatically behind the scenes, and we don't know how they are able to make it happen.
I do not understand how to replicate that by Inventor API code in Inventor 2024 though, because it seems like we've tried about every possible combination.  Since a DrawingDimension is one of the types of objects that we can specify as the first input for creating a GeometryIntent, it would seem like providing a SketchedSymbol would also work, due to certain similarities.  LeaderNotes use a DimensionStyle to dictate their style, just like a DrawingDimension, then the SketchedSymbol uses a LeaderStyle, which the DimensionStyle also uses, so I made the assumption that they may be compatible.  I have seen several cases where other types of objects would work for Inventor API methods, other than the ones mentioned in their 'help' documentation, so I was hoping this might be another case of that type of situation.  Maybe they just haven't exposed that specific functionality to us users yet, I don't know.
Wesley Crihfield
Message 8 of 8
omartin
Hey @WCrihfield, no worries thanks for taking the time to look at it. You are probably right the userInteraction must have some background stuff happening not available pragmatically (or some other steps may need to happen).
Through out the years both you and Curtis's input were a big help, I'm still digging up your old posts!
I am going to have to accept defeat on this one ...
For Posterity:
  • I found some other clues, when placed manually, the geometryIntent's parent is a leaderNode object but when using the createIntent function it is a sheet object (could have something to do with the not local error)
  • If you were to place the leader using the command manager and sendkeys, so your leader lands on the sketched geometry, It seems to work. Problem is a reliable way to get the screen coordinates
