[Assign / Update Item] using ilogic in Inventor
Michele_DeLucaSW7PJ
Michele_DeLucaSW7PJ
Hi everybody, there is a way how to do Assign/Update item in Inventor from Show Details pane? I'm in Inventor 2022
mfoster9TD82
You'll need to use the Vault API for that. The best way would probably be to make a .dll with all the Vault methods you need to use in Vault(see this AU course) but you can do it directly from iLogic if you need to, just add your references to the he...
AddReference "Autodesk.Connectivity.WebServices"
AddReference "Autodesk.DataManagement.Client.Framework.Vault"
AddReference "Connectivity.InventorAddin.EdmAddin"
Imports VDF = Autodesk.DataManagement.Client.Framework
Imports Autodesk.DataManagement.Client.Framework.Vault.Currency.Connections
Imports edm = Connectivity.InventorAddin.EdmAddin
AddReference "Connectivity.Application.VaultBase.dll" 'required
Imports VB = Connectivity.Application.VaultBase 'required
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports ACW = Autodesk.Connectivity.WebServices
You'll want to:
  1. get the part number and filepath from Inventor
  2. convert the filepath to a vault path
  3. find the file in vault
  4. get/create the item
  5. update the item
See this article for more specifics on updating items with the Vault API
Its probably easiest to just use the built in Vault tools in Inventor though.
Hope this helps
