Assign custom layers to specific geometry in .dxf
Context: I many large assemblies of wood cabinets. These cabinets are assembled with dowels, locator pins and screws. The machining involved 95% of the time is: an outer contour cut and several boring operations. ( 8mm, 5mm and 1mm)
Problem: My CAM software is able to import the part with the machining pre applied, so long as the name of the layer is pre-set with the machining info. ie ( TCHWOB0TCH16660 ). The outer contour will always be the same, but the inner features will need different layer names for the different bore hole sizes.
Question: How can I automate the assigning of layer names to holes of certain sizes. All holes of 5mm = layer name X5X, 1mm = layer name X1X ect
