Asset.FilenameAssetValue
with:
Dim fileNameValue As FilenameAssetValue
i get the filename: \1\Mats\*.png or 2\Mats\*.png
is there a way to get the full path of the file like:
C:\Pogramm (x86)\Common Files\Autodesk Shared\Materials\Textures\1\Mats\*.png?
HermJan.Otterman
if you use your own bitmaps in the appearances then you get the full path.
So when the path starts with a 1 or a 2 it will be a relative path to
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures\
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
