Assembly work features?
I am having trouble seeing how to access the origin workfeatures in a
assembly file. It seems like it should be simple, but I am missing it.
Can someone point me in the right direction?
Kent Keller
Member of the Autodesk Discussion Forum Moderator Program
Anyone??
Still struggling trying to find access to this..... part files are easy
Set oWorkPlanes =
ThisApplication.ActiveDocument.ComponentDefinition.WorkPlanes
but assembly files ??? Any help appreciated.
Kent Keller
"Kent Keller" wrote in message
news:E4F991D968B182495B958ADAC8A0F519@in.WebX.maYIadrTaRb...
> assembly file.
Haven't been exposed yet. Maybe next release?
Neil
news:18EBFB7D7B0AEF4D5BE0D3FC251610ED@in.WebX.maYIadrTaRb...
> Anyone??
> Set oWorkPlanes =
> Kent Keller
> > assembly file.
Thanks once again Neil......Boy that is surprising, and unfortunate.
8^( Well at least I can quit wasting time trying to find them 8^)
Kent Keller
"Neil Munro" wrote in message
news:8E55D706F59F48930F65DADD95D0CC77@in.WebX.maYIadrTaRb...
> Neil
possible workaround: the first part is always placed in assembly origin with
same axes/planes. If you can be shure that the part is not moved yet, use
the part workplanes instead. (depends on your problem...)
"Kent Keller" schrieb im Newsbeitrag
news:69470ECF797CF1DA66419DEB5B73278B@in.WebX.maYIadrTaRb...
> Kent Keller
> > Neil
Thanks. That would probably work in 95% of the cases, but I would hate the thought of
having to delete the base part after a couple hundred other parts referenced it. 8^)
Kent
"jpisarz" wrote in message
news:6376E6C4C8FD0342E8699A1AF796574F@in.WebX.maYIadrTaRb...
