Assembly simplified substitute won’t update
bkmadsen
bkmadsen
I am struggling with using iLogic for suppressing subs in an assembly then afterwards creating a simplified substitute.
When I change parameters making the iLogic unsupress another part, the simplified substitute won’t update unless I manually edits the simplified part by changing representation view to a different view. This updates the simplified substitute. I want this to happens automatically. Any suggestions?
tyler.warner
It would be helpful to see the code you currently have to help you improve it.
If this solved your problem or answered your question, please click ACCEPT SOLUTION.
If this helped you, please click LIKE.
bkmadsen
In attached video.
The master Model State has a pattern that controlles number of components. This is correct in the master model state.
But to get the substitute to reflect this, i have to go all the way into the substitute file and edit the simplification and pres ok to have it update.
